MaygZ
MaygZ last won the day on August 1 2019
MaygZ had the most liked content!
2 Followers
About MaygZ
  • Birthday 06/19/1965
member details
  • Location
    Romsey, Victoria
  • Tagline
    Blind progress is still progress.
Recent Profile Visitors
MaygZ's Achievements
  1. Does it run?
  2. Guys, I found this in random searching and I though it might be of help to all trying to remove body deadener mechanically. https://www.youtube.com/watch?v=CRphhE8sGIk The guy seems a bit 'unique', but I've never seen it removed this way before and it looks REALLY easy. Admin: if this should be somewhere else, please move it.
  3. I hope you find this series as inspirational as I do. Really Darling I'm watching a Zed video. https://www.youtube.com/playlist?list=PL0S6QXvooAG2d73FKm4NNE2JTu5HDKGxr
  4. Lurchos, your work on the roof panel from scratch is some of the best work I've seen you do. Well done mate. I hope you are very proud of the result of your efforts. MaygZ
  5. What headers did you go with?
  6. That's some seriously bad cutting skills. Or it might be very skilful if that used garden shears! Enjoy the journey. Keep the faith. Just log on here and study other journals if you start to lose momentum.
  7. Gordo, Did you build your own loom or buy one off the shelf? Where did you buy your loom/get it made? Who is your mate that set up the wiring? Are you running stock gauges or using after-market ones? Which taco did you end up going with and did it fit neatly into your dash? Do you still run with the zed dash or have you built a custom dash? Did you keep the same speedo (do you even run a speedo)? If so, how did you set it up? From where does it read? Did you have to go to a digital speedo? If you could squeeze in some details and photos regarding your loom and gauge set-up it would be appreciated. MaygZ
  8. Bushing Kit https://www.energysusp.com.au/product_info.php?products_id=7803
  9. Justjap.com https://justjap.com/bc-racing-coilover-suspension-kit-nissan-s30-240z-260z-280z-55mm-strut.html
  10. Please add others you find. MadDat http://www.maddat.com.au/suspension/240z-260z-s30
  11. TTT https://technotoytuning.com/
  12. AZC http://arizonazcar.com/
  13. Silvermine https://www.silverminemotors.com/datsun/datsun-240z
  14. https://www.apexengineered.com/ I haven't used them, but they look amazing.
  15. These look more solid than TTT or AZC kits. https://www.apexengineered.com/ Anyone used them?
