BobsYourUncle
Everything posted by BobsYourUncle
  1. Haven't updated this in a while, I've been swamped working on my thesis. I can see the light at the end of the tunnel on that now, so I don't feel so bad taking some time out to fiddle with my zed. As I've mentioned previously, I've got a set of triple dellortos sitting here gathering dust (still trying to get some air bleed restricters). I don't want to start putting them on until I've had a play with the L28 to see if it's running ok. As per http://www.viczcar.com/forum/index.php/topic,8402.0.html, I though my spark plugs may have indicated sealing issues. I've just done a compression test, and got 165-170psi all round (which I think is very good?), so I think it's just the flat tops running very rich. I'm trying to get a handle on tuning them (http://www.viczcar.com/forum/index.php/topic,8696.0.html), and I need to learn how to check my distributor advance. Tuning's a pain with no tacho - where can I get one of those engine-bay tacho deals, and how expensive are they? I might have to give up on getting my original tacho to work with the l28 electronic ignition . edit: Oh, and I've got some seriously noisy tappets at the moment, so there'll also be some adjustment under the rocker cover at some point.
  2. replying to my own post - looking at the cut-away diagram I've got, it would appear unscrewing the mixture screw adds more air from the airbox to the mixture, thereby leaning it out?
  3. Quick question - I've finally found some time to play with my zed, and am fiddling with the carbies. On the flat tops, which way should this screw be turned to lean it out? Screwing it down? Is that right? Note: I know they're crap, and I'm not keeping them, but my triples aren't ready to go on yet.
  4. any group buy discounts???
  5. I'm told if the scratch is deep enough to be felt with your fingernail, it can't be buffed out. What's the going cost to get a 260z windscreen replaced? Is it expensive/difficult due to the age of the car? My 260's windscreen has been scratched quite badly by old wiper blades, and eventually I was planning on replacing it...
  6. Thanks everyone - these plugs are from cylinders 5 and 6 (I think that's right, the 2 closest to the firewall). All plugs looked like this, except cylinder 1, which to me looked normal. I think I'll do a compression test - I've been looking for a reason to buy a compression tester for a while . I hardly ever drive the car at the moment - It had probably been 2-3 weeks since the engine was last started when I took that photo. What difference will running the car make? I would've thought if oil was getting in, it'd get worse by running the engine? As I don't drive it much, I don't really have a good figure for oil consumption - it is low at the moment though (as is the coolant - hope I don't have a cracked head...) Thanks for the offer Wayne - I'll do a compression test first, I don't really want to drive the car if I can avoid it until I can rule out any serious problems...
  7. I'm after some input on the condition of my spark plugs (photo attached). My conclusion is the fuel mixture is too rich, and there's some oil getting in there, but I'm a novice, so some expert opinions would be helpful
  8. I think the brake hoses have been replaced. I flushed the system this morning and drove home (~75kms) with no problems. I'm going to get a brake specialist to look at it this week.
  9. I've posted this on another forum (whirlpool), but I'm looking for some quick theories, so I'll post here too (hope that's alright ). I've just experienced a soft pedal on my 2005 BAII. I was doing highway driving, had probably done 40kms with minimal braking (and no issues), when all of a sudden my brake pedal went soft. The brakes still stopped fairly well. I checked the fluid, which was fine, and I couldn't see any leaks. After sitting around for a bit waiting for the towtruck, the pedal came back. So my question is, what can cause this, other than overheating fluid? And what would make fluid overheat when I'm not using the brakes very much? I can't feel anything that would indicate that the brakes were sticking as I was driving to heat them up. I've been for a few quick laps around the block, with no issues... Any ideas?
  10. ^^ I'm with him, how can I get my hands on a set of these?
  11. Well I haven't had much time lately to play with my zed, but I have been fiddling with the rear brakes and handbrake, which won't hold. Initially the handbrake lever would come all the way up before getting any resistance - I've since adjusted the brake shoes, and it now seems to engage about 3/4 of the way up. With the back of the car jacked, I can't turn the rear wheels like this. However, the handbrake doesn't hold the car on my sloped driveway. The rod under the car that attaches to the lever is at full adjustment, so I think i'm looking at a new cable (but this looks like a bugger of a job). Is there anything else that can reduce handbrake effectiveness? I've installed new drums and shoes, and I think I've bled the lines properly (not that this should matter for the handbrake?). Anything else?
  12. I had to do it on my 74 2+2... I'll take a pic tonight if I remember. You only need to trim the front (towards engine) edge. edit: as promised...
  13. I'm stuck at work. Stupid Americans wanting to demo products to clients before Christmas...
  14. The interior looks great. Who made it? I need to redo mine at some point...
  15. I'm missing the part in the 3rd picture. I know of a car that's being wrecked, I'll check it out next week before I try to get new ones made. Thanks for the pics!
  16. I think that's what I'm missing. Do you have a picture?
  17. As per the topic - I've got a front bumper to install (my car came without one), but I think I'm missing some pieces. Can someone post a picture of how there bumper attaches, the manual I've got isn't too clear on it. Thanks, Ian
  18. I should be good for any weekend if it's in the middle of the day, and close (ie Peter's place). North side's probably a bit far for me.
  19. We talking lunch time? I can probably find some time on the 20th, Peter's place is just up the road...
  20. I need the whole top cover, which is what the float hangs off. Anyone you know likely to have one? I can get one from the UK for ~$100 shipped, was hoping to get something local and cheaper. I'd be interested in 2 if the price was right.
  21. So, I started disassembling/cleaning/rebuilding my DHLA40s today, only to find that two of them have broken legs on the top cover that hold the float pin. Both have been repaired, and one seems to be holding, but the other is buggered. I don't suppose anyone has a spare top cover laying around?
  22. Ok, so it looks like you can't by the n1350 shoes anymore, I'll have to look at getting mine refurbished.
  23. How'd you go? I've looked into it a bit more, n1350 should be the right part. Where'd you get yours from?
  24. Well, I started nice and early, got the rear driver's side brakes apart, only to find that my '74 260z uses the earlier n1361 shaped shoes.The supercheap parts guide lists those for '72 and earlier 240's... Seems strange - now I'll have to get different shoes. Anyone want a set of new n1339 shoes?
  25. Well I've been slack, no updates or work on the car in a few weeks. I do have a big pile of parts waiting to go on though, hopefully I'll get some done this weekend: - new chrome front bumper (the ebay one) - new boss kit and horn button - clutch fork boot - rubber and leather gearstick boots, and leather handbrake boot - new headlights (although 1 got broken in shipping, replacement is on its way) and harness - manifold gasket... just waiting on a couple of pump jets and rebuild kits and I'll be stuck into my triples - brake pads for my hilux front disc conversion - new rear drums and shoes - new wiper blades
