jeff43
Everything posted by jeff43
  1. G'day James, PM sent. Cheers Jeff
  2. MCA struts, adjustable lower control arms, LCR masterpiece engine with FI throttle bodies, 918 orange ......... Your just bragging now. I love it!!!! Cheers Jealous Jeff (JJ)
  3. She runs, this is the first time this engine has been started in 13 years. Enjoy!!!! VID_20190224_174128000.mp4
  4. Looking good Jeff, It does feel good when you start putting the car back together with nice clean bits. I look forward to watching it all come together and one day soon hearing that LCR masterpiece come to life. Cheers Jeff
  5. Very nice. These old girls need a nice home.
  6. Thanks John and Bruce. It is always nice the get some appreciative comments. I'm very pleased with how the car is coming along. Cheers Jeff
  7. I'm not sure what the Turbo on it is but it looks pretty knackered so I will be putting a new turbo on it to best suit my requirements. I will use a decent ECU so as to have good tuning control. An Rb would be nice but as I get older I like the concept of keeping a period old school engine in the car. Having said that it needs to drive well unlike my first 240Z that I had when I was 19. It was harder to sort out engine tuning back then with no money and no idea. Good luck with the RB, I would love to drive a 240Z with a 26 in it I think it would be sensational. Cheers Jeff
  8. Thanks, pretty happy with the progress and thanks for the interest. So I have an N42 block, P90 head, setup as turbo as it stands, I'm not sure what it was out of, but it had a front sump. So I will either keep it turbo and set it up for drive ability over out and out power or I may change it to NA with either 280ZX fuel injection manifold and aftermarket ecu or ITB's or triple carbs. Not yet decided - I keep changing my mind. Cheers Jeff
  9. So my mate Vorn came over this morning and gave me a hand to slip the engine and gearbox in the car. All went smoothly and for the first time in 7 odd years there is an engine in the bay. This is the original L24, I will get the car driving with this engine and then in the next year or so I will sort out the L28 out and slip it in. Check out the pics. Cheers Jeff
  10. Hi Matt, I have replied. Cheers Jeff
  11. Very nice John, Good to see after 18 months, you haven't lost any of your skills!
  12. I have been able to get a bit done this week. The engine bay is looking a bit busier, voltage reg, inspection lamp, fuel filter bracket, coil mount bracket and steering coupling all fitted and connected. Most of the sound deadening is installed, I have used Carbuilders OEM black. The steering wheel and pedal box are all fitted, as is the tail light trim panels, number plate light etc. Got a new number plate for Xmas as well. Cheers Jeff
  13. Anyone like the polished metal look for the tail light surrounds (trim).
  14. NUF said. Thanks Simon. Makes me feel chuffed!!!!
  15. Just a few pics from today. The engine wiring loom has had a clean and been fitted, along with the air intake ducts. I also finally fitted my wilwood proportioning valve in the stock location ( for an early car) at the rear underside above the RH half shaft. Just a quick note on the Wilwood brakes and the proportioning valve fitment etc. Wilwood do not make a proportioning valve with the correct thread and flare to fit directly to our Datsun's. After a lot of searching I did manage to find a set of adaptors which allowed me to fit the valve without needing to change brake line fittings and redo the flare on the brake line. I have added the ebay link below, I hope it can help other people in the future. Cheers Jeff https://www.ebay.com.au/itm/Brake-Line-Thread-Adapter-Male-M10-x-1-Bubble-Female-M10-x-1-Inverted/391200008314?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
  16. Thanks Roger, you and me both - I can't wait to have it out on the road. Quite enjoying this part of the build. Thanks, I'm very happy with how it is coming along.
  17. I'm enjoying this build Jeff. It is working out nicely for me as I'm a few steps behind you, which allows me to learn from any of your mistakes - Gold. Just kidding, you are doing a great job and it does help me to see what you have done about a month before I get to do the same thing on my car. Keep up the good work. Cheers Jeff
  18. Jan 19 update - this is the year, we will drive this car this year!!!! For the first time in 7 years the old girl is back on it's wheels - a bit of a milestone there. I will let the pics tell the story. Cheers Jeff
  19. That is the same as mine on the original engine from chassis 00134, compliance plate dated 11/70.
  20. Wow! That's an effort and a half to get it together in that time frame. Your making me feel bad that I have taken 7 years so far and I have only just started putting mine back together - and I started with less rust. Looks good too, must be nice to drive with some RB25DET oomph under the bonnet. Nice that you get to enjoy the drive whilst you get the last bits done. Cheers Jeff
  21. Hi Jeff, On Vorn's 240Z, he used some "adel" clamps mounted off the front of the head to hold his fuel lines - could be an option for your fuel lines. Cheers Jeff
  22. I expect so, they were removed from a crashed car. I cannot be sure though, not tested.
  23. This is why I put a pool in the backyard. I'm not sure how much work will get done in the tin shed over the next week, maybe a bit late at night when the sun has gone down. I prepped the extractors with the wire wheel in the cool of Sunday - only 35 ish.
  24. It all came down to price for me Gav, $20 and a bit of hard yakka vs the cost of HPC coating - which in the hundreds.
  25. I needed to paint my extractors, the product instructions said to bake after painting @ 200 Deg C for 1hr. I don't have an oven big enough to do that and I'm sure the wife wouldn't be happy with that. So when I saw the weather forecast for the next week I decided it was now or never and prepped the extractors for paint. I figured a week of baking on the pavers in the sun will have to do.
