Scoota G
Everything posted by Scoota G
  1. I feel bad now, no i didn't buy it. If someone doesn't i will. My Bad. Seriously i have two 260Z's and i would trade my 2 Seater for this no probs.
  2. SOLD . . . To me, there goes my deposit for that block of land!
  3. Yep measurements look good. Just get some 260Z or 2+2 mounts. I did strip some seats down, i may have kept the parts you are after.
  4. Lol yea that was me. I get piture messages sent to my other number. I'll just measure it now.
  5. I just recovered a 260Z seat today, measure the distance between the bolts on each section centre to centre and send me a text 0n 0four05two98four1one and i'll measure mine to confirm that it can be done.
  6. That's the bendy little poof of a thing
  7. Yep, swapped dale for a set of stock rims. PM Replied
  8. If you stuff them up i have about 3 sets here.
  9. That would be the twisty one that turns around and underneath itself. I may have a used one. I'll check but when mine blew and i couldn't find a replacement i went to supercheap bought a piece of hose with the 180 bend and fitted a 90 degree brass fitting to fit it up to the core.
  10. I have rebuilt toyota calipers on my Zed (V8) and had them apart and replaced the seals. Pulled a neg 1.47 G's on the roadworthy brake test. No Issue.
  11. Got a set of 4. I'll get a picture up.
  12. I used one from a late 80's model bluebird.
  13. Scoota G
    260z Hubs
    As Above. He's back from holidays now.
  14. With vehicle running remove the negative lead from the battery. If she stops she's snuffed!
  15. I run the mechanical pump with Triple 45MM Dellortos on a mild street motor. Never had an issue.
  16. Been hanging out for this one
  17. All boxed up, details are on the facebook post.
  18. Looking fo a few parts to make my 490Z (260Z 2+2) a little better, chasing the following parts; Passenger side rear quarter window and both side mounting brackets (brackets must have no rust). Black kick panels that hold the carpet down on the side (need to be near perfect) One lower seat vinyl can be from either side (also must be very good condition). Hopefully someone can help me out, these parts would finish off my interior to near perfect. Thanks Gents.
  19. Scoota G
    260z Hubs
    I gave rob in Ballarat a set. Pm fuzzydropbear.
  20. Replaced with the manual one would be the go.
  21. My mistake it is a drivers side one. In very good condition too. I'll post photos on your wall.
  22. I did save a door off the 2+2 i pinched off AussieZed. Can't remember which side it was. I'll check.
  23. Didn't get a ride, mick seemed a bit busy and it rained heavily just when i showed up. Love the V8 Zeds.
  24. Just dropped in to see Mick and the heavens opened. Gee mick you sure do block out some sun.
