Showing content with the highest reputation on 12/13/2022 in all areas
  1. Well change of approach and getting a proper resto with Lachlan at C.A.R Fortunately not too many surprises were found lol.
    2 points
  2. Michael
    Thai Fender Mirrors.
    Will do once it's painted. the blue was a vinyl wrap, - (Signwriter by trade) It had 2 different batch numbers on it, One of which went bad after application. Thought it'd be worthwhile painting it rather than another rewrap.
    1 point
  3. Errrrrrrrr.... Needing replacing: L & R Outer sills. Underfloor chassis rails. Doglegs. Slam Panel. Radiator cross-member. Top Rear of Left engine bay frame rail. Inner skirt under battery tray. LH firewall where skirt joins it. HVAC plenum duct is all but gone at it's base. Pin holes in plenum floor. Rust holes in plenum top. RH floor pan requires a couple of patch's (fore & aft). Tail light panel needs sections replaced. Rust in the rear of the drip rails. Lots of pin holes to weld up. Major Accident damage to both rear quarters which will will require a lot of straightening: And that's not including the guards, doors, bonnet, hatch, scuttle... On a positive note, the sills, rails & slam panel have arrived from KlassicFab:
    0 points
