Showing content with the highest reputation on 08/30/2021 in all areas
  1. It will be back on Car sales shortly
    2 points
  2. People often ask about wheel options for Z's. You need to know 3 things to select your wheels/tyres; 1. PCD which is distance from center hole to center hole on the wheel stud holes. For the S30 it's 4 studs at 114.3mm. 2. Offset or back space which is explained in the diagrams above. The stock 240 runs ethier 0mm or +12mm from memory. Just keep in mind the higher the negative value the deeper the dish. For instance -20 gives you 20mm more dish than the same wheel with 0 offset. This would also mean that the wheel with the -20 offset would also sit 20mm closer to the wheel guards than the 0 offset when put on the same car. There is a limited amount of space between the stock guards and suspension. This space limits your wheel offset and size options. For instance alot of wheels on the market are designed for newer front wheel drive cars with a +35 offset. If mounted on a Z these wheels would rub on the suspension as they would sit too far in. One way around this is using a bolt on spacer that pushed the wheel out. These spacers can be made to order and bolt on to your existing hub. I've used them before and there is much discussion on the net about them. Installing aftermarket suspension like coil over gets you some more room as does installing flares but I won't go into that as there is much discussion on that in other areas on this forum. 3. Rolling diameter is based on the diameter of the stock tyres. Not sure what the 240's is but I think the tyres I'm running are about 620mm. To work it out just add the height of the tyre walls to the wheel size. Just remember a 225x50 tyre is 50% of 225mm so tyre wall height is 112.5mm. Apart from looking like crap getting the rolling diamter wrong can put your speedo out. For those that have been down this road and would like to comment on wheels/tyres you have found to fit on a Z car please add your comments and pics. To help others out please try and include info like offset and tyre size etc Years ago I came across a page on the net that had a comprehensive list and pics of stock wheels from other cars that bolt on to the stock Z car. If anybody has a link to this info please share! My contribution might not be helpful to many as I've got flares on my car but I'll try to kick start the thread with my set up. I bought 3 piece ROH Venturo wheels in 17 inch. 17x8.5 (-6 offset) for front and 17x9.5 (-19 offset) at the back. 5-6 weeks to be made. I think tyres are 225x45 front & 255x40 rears.
    1 point
  3. Hi all, i've bought a 260Z that 2 previous owners ago has put in a L20ET engine in to. The previous owner who bought it from someone else says that he was told there is an electrical problem and hence the car does not start. It looks like the car hasn't been started since the engine has gone in. Is there anyone in Queensland who is able to help me figure out the wiring and get this thing started? It looks like the people who put the engine in has had a go at the wiring and hasn't been able to figure it out. My plan is to get the car started by spraying Nulon's "Start Ya Bastard" in to the air intake. Once i get it to start using the spray, i can move on to the fuel relays etc because all the fuel rubber hoses are currently degraded and broken. So I've disconnected the fuel pump because the last person has run power directly to fuel pump rather than going through the relay. These are the things that i've done to try figure out the wiring. I've confirmed the ignition coil is good. I put power to '+' and then grounded the '-' side manually a couple of times and confirmed I can manually produce a spark with a spark plug connected to the ignition coil output I've run 12V to the positive side of power transistor of the "T plug" (black with white strip wire). Then I've run from pin 5 of plug 2 to the negative side of "T plug". My hope was that when i crank the engine, the ECU would ground the negative side and cause a spark from the ignition coil. This did not happen. I've confirmed i've got 12V at injector 6. Oddly there is constant power there on both pins of the injector connector at all times. I assume however, ecu grounds 1 pin during normal operation to get it to eject fuel. However if i disconnect all of the fusible links, shouldn't i lose power to 1 or both of the pins on the injector plug? Why does it need/have constant 12V with the key in the off position/all fusible links disconnected? I've found the attached pinout diagram for an L20ET ECU. But i don't know if this is actually the correct one. To test if it is correct, i disconnected the fusible links one by one and checked if the power to the dash at the ON position would stay on. The only time I lost power is when Fusible Link 1 was disonnected. For perspective, I've numbered the fusible links from left to right (3, 2, 1). FYI, I only have 3 fusible links - not 4. I have 2 plugs with wires that comes out of the ECU and also leave from these plugs and some goes towards the engine. I've traced the wires that comes from ECU to these plugs. Please see attached picture - Plugs 2&3 tracing.jpg - and close up pics of Plugs 2 & 3. These are located at the passenger side foot well. Let me know if you have any advice. Would love it if someone could come out and give me a hand to help figure out the wiring.
    1 point
