Scoota G Posted May 2, 2011 Posted May 2, 2011 Got an interesting new task at hand, a clients 67 Fastback that needs new rails and floor pans. Quote
PZG302 Posted May 2, 2011 Posted May 2, 2011 Nice, and being seppo should be a lot easier to work on than a Z, with it's finer engineering tolerances. Quote
C.A.R. Posted May 2, 2011 Posted May 2, 2011 Nice, and being seppo should be a lot easier to work on than a Z, with it's finer engineering tolerances. I see what you did there Quote
gilltech Posted May 2, 2011 Posted May 2, 2011 I've fully restored a couple of '67s now, a CV & a FB, & yes the panel gaps & tolerances are indeed a tad (or two) wider than on our 70's era Zeds! However, one does appreciate the heavier gauge panel steel on the Mustangs. As an owner of both a '67 FB & a 260Z I can tell you that the two cars are definitely chalk & cheese, quite different approaches engineering-wise to 2-door personal transport. FWIW if a Mustang or whatever needs replacement panels such as the floor then I advise to try & obtain American-steel replacement panels or patch panels. Quote
Scoota G Posted May 2, 2011 Author Posted May 2, 2011 Yep steering clear of the tiawanese parts and going for Drake. Quote
benny Posted May 3, 2011 Posted May 3, 2011 yikes!! that does need some work!! you're the man for it scoot!! Quote
gilltech Posted May 4, 2011 Posted May 4, 2011 So obviously the inner front apron, where the battery tray bolts in, has had an old repair patch overlay; a temporary fix at best. Rust to the apron is very common in that location due to battery fluid spill causing corrosion which eats it's way through the steel tray & eventually down through the apron. I've had to repair or replace these on both my 67's. Easily fixed, access is good, the apron panel is simply drilled off, a new one welded in & painted, & a new battery tray bolted on. Quote
Scoota G Posted May 4, 2011 Author Posted May 4, 2011 the apron panel is simply drilled off, a new one welded in & painted. Someone has already played around with the exterior and done that. The only visable area on the outside of the body with the rust is in front of the rear wheel arches. Quote
C.A.R. Posted May 10, 2011 Posted May 10, 2011 Looking good mate. The butcher who bodged up the repairs before you, should be shot! Quote
Sirpent Posted May 10, 2011 Posted May 10, 2011 Nice work Scoota, Was that a Maxwell House coffee can? Seen some funny stuff emerge from beneath paintwork in the way of repairs in my time but thats ones for the books LOL Quote
Scoota G Posted May 11, 2011 Author Posted May 11, 2011 Nice work Scoota, Was that a Maxwell House coffee can? Sure was. Three signs were also used to repair the floor. One was an electrical hazard sign and another was a goodyear tyre sign. Quote
FuzzyDropbear Posted May 11, 2011 Posted May 11, 2011 Hey scoota, lookin' good mate, I might have to drop around for a look-see At least its come to someone who's going to do the job properly this time! Quote
Scoota G Posted May 14, 2011 Author Posted May 14, 2011 Hey scoota, lookin' good mate, I might have to drop around for a look-see At least its come to someone who's going to do the job properly this time! Cool Rob, no sweat. More pics Quote
Scoota G Posted May 21, 2011 Author Posted May 21, 2011 Passenger side floorpan and seat pan are in. Quote
Scoota G Posted May 31, 2011 Author Posted May 31, 2011 Rust Much? This is where the floorpan problems start with this model. Quote
benny Posted May 31, 2011 Posted May 31, 2011 WOW big project there scoot... im sure you are the man for it though!! Quote
Scoota G Posted May 31, 2011 Author Posted May 31, 2011 It is a bit of a task but at this stage rust replacement panels go in easy. Quote
KatoKid Posted May 31, 2011 Posted May 31, 2011 Nice Scoota. Must be good to be able to buy all the repair sections....that last one would be a bastard to make! Quote
Scoota G Posted May 31, 2011 Author Posted May 31, 2011 ....that last one would be a bastard to make! Ha no doubt, the owner has dropped me a couple of G's for parts but both sides of the cowl were only $136 from East Coast Mustangs up in Lilydale. Quote
