Bruce Posted September 1, 2006 Posted September 1, 2006 Hi Guys, what can you recommend to attach the side pillar emblems. They appear to be currently held in with little or no adhesive and have come off quite easily. Any thoughts? cheers Bruce Quote
RUSSJZ-ZED Posted September 1, 2006 Posted September 1, 2006 a thin bead of plumbers neutral cure silicone, ,will hold it real tight, but removable if you need to repaint. Don't use glue! You will never get them off undamaged. Quote
Huw Posted September 1, 2006 Posted September 1, 2006 sikaflex is king if you don't want them to come out again :-) Quote
thehelix112 Posted September 1, 2006 Posted September 1, 2006 Thats good advice. I lost one of mine somewhere around 115mph down the 1/4 at Heathcote. Dave Quote
Administrators gav240z Posted September 2, 2006 Administrators Posted September 2, 2006 I believe Sulio has had good luck with Sicaflex so far. :lol: Quote
Toecutter Posted September 2, 2006 Posted September 2, 2006 Yer I'm gonna go Sicaflex crazy. I used it on my badges and rear spoiler. Man that stuff holds. When I went to remove my side DATSUN badges to put the fairlady ones on it took a bit of effort removing them. I used silicone once and the badge came off lucky I found one at Heathcote though! Quote
thehelix112 Posted September 2, 2006 Posted September 2, 2006 Its ok, I am debadging the car and smoothing everything at some point anyway. Dave Quote
