datsunrally Posted September 6, 2021 Posted September 6, 2021 Hi all, I'm seeking a bunch of standard exhaust engine pipe nuts (see attached pic), between 4-8 depending on availability. If you've upgraded your Zed to extractors you may have some lying around, if so, please get in touch. Thanks, Jeff Quote
datsunrally Posted January 21, 2022 Author Posted January 21, 2022 Giving this a little bump, as well as adding a photo. Anyone know where I can find these nuts? Thanks! Quote
datsunrally Posted January 21, 2022 Author Posted January 21, 2022 (edited) A sensible suggestion but NLA. FWIW the part number is 20602-A7100. Edited January 21, 2022 by datsunrally Added the part number Quote
C.A.R. Posted January 21, 2022 Posted January 21, 2022 Have you tried an exhaust shop? Auto parts stores? Quote
NickF Posted January 21, 2022 Posted January 21, 2022 Try National Nuts and Bolts Geelong have a great range and I have sourced some long nuts from them. Very helpful Nick Quote
AndBir Posted January 21, 2022 Posted January 21, 2022 6 hours ago, datsunrally said: Anyone know where I can find these nuts? Try here : https://www.jnsfasteners.com.au/collections/exhaust-studs-and-nuts/products/steel-nuts-m8-x1-25-nissan-qpp-10 Photo does not show the length but this is where I got mine from. Quote
datsunrally Posted January 21, 2022 Author Posted January 21, 2022 Thanks for the suggestions, I have started research using a slightly later part number and have made some progress. Jeff Quote
AndBir Posted February 15, 2022 Posted February 15, 2022 Not sure how you went with these but these were what was on a '74 260z Quote
datsunrally Posted February 15, 2022 Author Posted February 15, 2022 Hmm, that's interesting. Maybe there were a couple of different types used by Nissan over the years? The OEM part number searches all ended up NLA so I went for the JNS option you suggested, thanks for that by the way. Do you think the rusty treasures you removed from the manifold are usable / rescuable? Jeff Quote
AndBir Posted February 20, 2022 Posted February 20, 2022 On 2/15/2022 at 2:02 PM, datsunrally said: Do you think the rusty treasures you removed from the manifold are usable / rescuable? Two came off very easily, the third remains on the stud but none look badly rusted. Quote
Bobby Posted February 20, 2022 Posted February 20, 2022 Hello Datsunrally, Do you have any friends with a lathe? I made my own manifold nuts from 1/2" hex brass bar and drilled and tapped for 8mm. Not sure what thread yours would have been but probably 10mm so would need larger hex bar than I used. Brass is the best material to use. Do not use stainless as you can get what some call "pickup or galling" when you undo. If you go with steel just use plenty of never seeze on the thread. Quote
datsunrally Posted February 20, 2022 Author Posted February 20, 2022 Hi Bobby, I do know somebody with a lathe and making some brass long nuts is certainly on the cards. In the meantime, I have some off-the-shelf JNS 8mm long nuts that will do the job. Thanks for the suggestion BTW. That's a lovely engine bay, job well done! Jeff Quote
Enzo Posted February 20, 2022 Posted February 20, 2022 Brass Exhaust Manifold Nuts - Metric Pitch High Temp Inlet M8 M10 & UNF UNC | eBay Quote
