Mr240z Posted August 26, 2008 Posted August 26, 2008 Hi looking to buy a pair of s12+8 hilux/4runner calipers cheap in sydney any ideas would be nice Thanks paul mr240z Quote
XRQTR Posted August 26, 2008 Posted August 26, 2008 I'm sure there would be some wreckers close by, best place to start. Quote
mayhem Posted August 26, 2008 Posted August 26, 2008 there is a set on ebay for $80 sorry dont know how to link Quote
luvemfast Posted August 27, 2008 Posted August 27, 2008 http://cgi.ebay.com.au/Toyota-hilux-4runner-CALIPERS-BRAKE-UPGRADE-240Z-260Z_W0QQitemZ110283505188QQihZ001QQcategoryZ42605QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Here you go. I was talking with Gerhard Metz on Sunday and he has Nissan 4 spots with a Ford rotor that is an easy conversion. Just bung the holes in the caliper and redrill. Bore out the ID on the rotor and shave some material off the face. Done. Quote
Moderators Zedman240® Posted August 27, 2008 Moderators Posted August 27, 2008 I've done the same Gearhard Metz conversion before and it works very well. Bit of running around to do but worth it. From memory you need a disc DBA106B (the B is for Blank ie no holes for wheel studs) and you need to machine 6-7mm from the hub face where the disc mounts (to move the disc further out) and as luvemfast says bung the holes and you are done! Best thing about it you have a caliper that says Nissan too! Quote
C.A.R. Posted August 27, 2008 Posted August 27, 2008 Problem is, last time i checked DBA won't sell undrilled rotors anymore... Quote
Mr240z Posted August 27, 2008 Author Posted August 27, 2008 Lurch dont this s12+8 calipers fit on stock 240z rotors Quote
C.A.R. Posted August 27, 2008 Posted August 27, 2008 Yes the 12+8 calipers do - see Sulio's Zed. The later model S12 calipers are for vented rotors. Quote
Mr240z Posted August 27, 2008 Author Posted August 27, 2008 Thanks guys for the input answered my question .Pleasure being part of such a top bunch of Z lovers and a great website club aswell thanks heaps Quote
Toecutter Posted August 28, 2008 Posted August 28, 2008 yer i think the S12+8's on my car are off a 83 to 89 hilux. they fit great and are working great with the stock 7/8 master cylinder. Sulio Quote
Hunter Posted September 19, 2008 Posted September 19, 2008 I read somewhere that the HILUX VENTED ROTOR CLAIPER or the HILUX NON-VENTED ROTOR CALIPER will both work on a standard S-30 NON-VENTED ROTOR. The pistons on the VENTED ROTOR CALIPER will push in enough to work on NON-VENTED ROTOR. But the gap on the NON-VENTED ROTOR CALIPER is not wide enough to take the VENTED ROTOR. The following install uses the S12+8 calipers on a non vented rotor. http://atlanticz.ca/zclub/techtips/toyotabrakeupgrade/index.html Read this thread S12/W is written on the side of the Wide vented rotor setup. http://forums.hybridz.org/showthread.php?t=104735 Here is another Brake FAQ http://forums.hybridz.org/showthread.php?t=103767 CAN ANYONE CONFIRM THIS??? Quote
sco_aus Posted September 19, 2008 Posted September 19, 2008 Yes that is true, I have a pair of both sets of callipers at home, they will both work. Unfortunately the vented ones are cracked or id say they are for sale and he others are on my car. Quote
Hunter Posted September 19, 2008 Posted September 19, 2008 your vented ones did not crack because the pistons had to travel so far did they? Quote
sco_aus Posted September 19, 2008 Posted September 19, 2008 lol, no. The guy who gave them to me had grinded a bit of metal off to make them fit his 120y, but they failed. They had just been rebuilt so he gave me them for the pads and any other parts i might be able to use from them. Quote
