aircobra 63 Posted November 8, 2020 Share Posted November 8, 2020 i'm thinking of converting my points, but would like to keep the coil, wiring and the tacho has anyone tried one of these? https://www.ebay.com.au/itm/Electronic-Ignition-Conversion-Kit-for-Datsun-Nissan-240Z-6-cyl-Hitachi-Dist/312585498500?hash=item48c78c2f84:g:8AsAAOSwwbdWJn8v Quote Link to post Share on other sites
0 GongZ 280 Posted November 8, 2020 Share Posted November 8, 2020 (edited) I don't know anything about that option, but it's similar to the Pertronix 1761 (there is a version II too) If you put "site:www.viczcar.com pertronix" into your favourite search engine, you will see plenty of posts on here about it. One of the posts (from Gavin) recommends this article for background information - https://www.hagerty.com/media/maintenance-and-tech/ignition-debate-points-vs-pertronix/?utm_source=SFMC&utm_medium=email&utm_content=19_January_30_HagertyNews Edited November 8, 2020 by GongZ Quote Link to post Share on other sites
0 24 Dat 138 Posted November 9, 2020 Share Posted November 9, 2020 I know a guy who has one of these in his 260Z apparently is is fantastic https://www.123ignitionshop.com/gb/tune-plus-datsun/199-123tuneplus6rvdatsun-bluetooth.html still looks like a 240Z Distributor but it is $ Quote Link to post Share on other sites
0 C.A.F. 1,128 Posted November 9, 2020 Share Posted November 9, 2020 12 hours ago, 24 Dat said: I know a guy who has one of these in his 260Z apparently is is fantastic https://www.123ignitionshop.com/gb/tune-plus-datsun/199-123tuneplus6rvdatsun-bluetooth.html still looks like a 240Z Distributor but it is $ I get mixed reviews on these. Some work. Some don't. FWIW I sent Scorcher to a mate in Cali because he couldn't get his 123 to work properly and the 123 dealer couldn't help either... gav240z 1 Quote Link to post Share on other sites
0 Administrators gav240z 2,491 Posted November 12, 2020 Administrators Share Posted November 12, 2020 I was looking to get the 123 Ignition set up also but after reading reviews about some mediocre parts on 1 of the Z forums and from Lachlan's feedback I decided to hold off. I think the cheapest option (if you're original points distributor is still in good working order) is to go Pertronix ignitor option. I'm considering it for my white 71 which is very original and I kind of want to keep the points distributor on it. Quote Link to post Share on other sites
0 peter t 200 Posted November 12, 2020 Share Posted November 12, 2020 (edited) I use a FAST (CRANE) and is easy to install. Had one module fail in ten years so I just have a spare in the glove box in case. Not that expensive and good enough for a road car. I have a friend who has a 123 and he has had no problems. Edited November 12, 2020 by peter t Quote Link to post Share on other sites
0 krizza 17 Posted November 15, 2020 Share Posted November 15, 2020 I'm with PeterT. I tried the pertronix and was unhappy with the result. I changed to the Fast xr700 and am very happy with it. Great ignition and no issues. If you want to keep the stock tacho then this is the best choice imho. If not then an MSD 6AL is the go. gav240z 1 Quote Link to post Share on other sites
0 Enzo 113 Posted November 15, 2020 Share Posted November 15, 2020 I used the Crane XR700 for years but fried it when I stuffed up some other wiring. Great unit. I now have the Hot Spark ignition module (as in the first post) with the Beru Blue coil. No resistor is required for this setup ( Full 12V). A coil with more than 3.0 ohms of primary resistance is also required. You have to be careful with voltage polarity with the Hot Spark unit or you can fry it as well. I am currently using the above with the FiTech 30003 4 barrel EFI on a Arizona Z dual plane manifold. The standard 260z Tacho works with this setup. The crane XR700 requires the existing resistor in line. The Crane XR3000 deletes the resistor. I have never used a Pertronix unit but would go back to Crane (Now Fast) unit if using an original distributor. I do keep a spare original distributor with points in storage behind the seat just in case. Regards David. Quote Link to post Share on other sites
0 aircobra 63 Posted November 15, 2020 Author Share Posted November 15, 2020 enzo, does anyone sell these locally or did you have it shipped from the US? Quote Link to post Share on other sites
0 Enzo 113 Posted November 15, 2020 Share Posted November 15, 2020 From the USA with the Beru Blue coil. Quote Link to post Share on other sites
0 Administrators gav240z 2,491 Posted November 15, 2020 Administrators Share Posted November 15, 2020 https://www.classiczcars.com/forums/topic/16390-installing-the-crane-xr3000-ignition-system-in-a-72-240-z-part-2/ Quote Link to post Share on other sites
Question
aircobra 63
Link to post
10 answers to this question
