240z71 Posted July 5, 2020 Posted July 5, 2020 (edited) Hey Guys Thought id upload some photos of a little side project I’ve been working on while assembling my Z. Had the idea one day to combine the rear drop down suspension cradle and moustache bar after realising how weak the standard items are and not being a real fan of the agricultural looking aftermarket solutions or the design of the standard moustache bar for that matter. I looked to the modern WRX’s which also run the r180’s and decided to use the bush out of the mid 2000’s WRX. had some sleeves machined up to suit and build a jig around the standard items. This is what I came up with in the end. Fully built out of 4130 Chromoly Excuse the Poor photography. Still yet to press the bushes into the sleeves but you get the picture. The idea is to use this along with the SWM front diff member and will put the R180 in the later further back position and should significantly increase the rigidity of the suspension mounting points as well as utilise a better way of mounting the diff over the standard design. let me know what you guys think. Thanks Matt Edited July 5, 2020 by 240z71 Ponyo240z and GregTas 2 Quote
260DET Posted July 5, 2020 Posted July 5, 2020 Looks good to me, perhaps a fore/aft brace to the chassis too? Quote
CBR Jeff Posted July 6, 2020 Posted July 6, 2020 Nice work Matt. Removing the horizontal movement of the mustache bar (shock absorbing effect) may require some further strengthening or bracing to support your new structure. The forces associated with acceleration and breaking will now be transferred to other points not absorbed the spring of the mustache bar. Jeff Quote
240z71 Posted July 6, 2020 Author Posted July 6, 2020 10 hours ago, KatoKid said: Nice! Serious surge tank.....cos race car? Thanks Mate. Yup cos race car, car is solely designed for tarmac rally events but will also see the odd track day. If I even finish the bloody thing. Thanks. Quote
240z71 Posted July 6, 2020 Author Posted July 6, 2020 10 hours ago, CBR Jeff said: Nice work Matt. Removing the horizontal movement of the mustache bar (shock absorbing effect) may require some further strengthening or bracing to support your new structure. The forces associated with acceleration and breaking will now be transferred to other points not absorbed the spring of the mustache bar. Jeff Thanks Jeff. This was the main consideration in my design, the lack of spring that is seen in the original bar. I’m pretty confident in the restraints of the member for countering the thrust force from the diff under acceleration and braking. Utilising the drop down bolts of the original moustache bar and the bolts of the drop down links using the flat plate means there is absolutely no give in unit, but that’s only giving it the old He-man test. The other thing I though of whilst making it is that the front diff member is just as susceptible to the thrust force from the diff accelerating and braking, if there is no fore and aft movement up front (i.e the SWM mount) then little force should be transferred to the rear cradle. Also the rear control arms will provide further restraint when bolted in joining the front and rear members.? I could run a SpaceGass analysis of it if I get time. But I might just add some gussets and wait till the car is driving to give it a good shake down and go from there. Appreciate the feedback guys Thanks Matt GregTas and CBR Jeff 2 Quote
260DET Posted July 6, 2020 Posted July 6, 2020 Relevant comment on the front X member Matt, my race experience with the 280ZX 2+0 is that it's stock bolt system which is similar to a S30's comes loose, the nuts specifically. Because of that I have made some fore/aft supports hence my earlier comment, their weight is insignificant. I have bigger brakes so the loads involved when braking particularly are significant. Quote
240z71 Posted September 27, 2020 Author Posted September 27, 2020 Hey guys ended up making a few revisions to the jig and made a version 2.0. Got it powder coated and installed the bushing and threw it in the car. Still need to get bushing for the control arms but looks the business with a set of Dave’s chromoly rear arms. still need to also get some m14 read diff studs made up. Standards are m12 so there a bit loose in the bush centres ATM. Thanks Matt KatoKid and Ponyo240z 2 Quote
