Kavs Posted June 21, 2020 Posted June 21, 2020 Hi all, Has anyone ran this size before, XXR 536 16X8 4-100/4-4.5? Cheers, Matt Quote
OdinZ Posted June 23, 2020 Posted June 23, 2020 Am I reading correct, stud pattern 4x100? If so, then that wont fit. S30 are 4x114.3 Also, have a look through here to sit what sizes others have run: Then use a site like below to see how they sit compared to others: https://www.willtheyfit.com/ Quote
GregTas Posted June 23, 2020 Posted June 23, 2020 (edited) 16x8 +4 offset. 225x45x16 Tyres. Std guards with lips tapped up. No scraping of tyres. Edited June 23, 2020 by GregTas gilltech and OdinZ 2 Quote
Kavs Posted June 24, 2020 Author Posted June 24, 2020 Doe you think your set up work still work if it was a +24 offset? 19 hours ago, GregTas said: 16x8 +4 offset. 225x45x16 Tyres. Std guards with lips tapped up. No scraping of tyres. Quote
CBR Jeff Posted June 24, 2020 Posted June 24, 2020 Load your before into this then play with the after. Try to maintain a 0 scrub radius. 195-65-14 -14 5.5 is a standard 240/60 mag wheel. You will need to get a measuring stick out. Jeff https://www.wheel-size.com/calc/?wheel1=195-65-14X5.5ET14&wheel2=205-55-15X7ET15&fcl=20mm&scl=30mm&wcl=20mm&sr=0mm Quote
Cozza Posted June 24, 2020 Posted June 24, 2020 1 hour ago, Kavs said: Doe you think your set up work still work if it was a +24 offset? Are you running standard struts or maybe coilovers with narrow diameter spring and perch with standard struts a +24 would hit the spring perch. Quote
Kavs Posted June 24, 2020 Author Posted June 24, 2020 Yeh standard, always trade off's do you know what the limit is with + off set's? sorry I'm not too knowledgable with any of this. Quote
