Barra260Z Posted June 30, 2017 Posted June 30, 2017 Rb25det conversion to suit 260z 2+2 G'day guys For sale I have my rb25det engine with 5 speed manual box has forward facing greddy plenum, throttle body adapotor to use factory throttle body, or comes with after market throttle body aswell, brand new 5 puk clutch, has never been driven using only run on stands using the clutch, it is literally brand new, rear hump sump and modified pickup to suit, minus turbo and manifild and exhaust otherwise complete engine, comes with air con pump, power steering pump, clutch fan etc Engine has the right hoses you need to plumb the heater core in and radiator hoses Comes with new braided turbo lines for low mount turbo, complete aftermarket wiring harness by wiring specialties in America , the aftermarket harness is a work of art, The harness uses all factory connectors, has own relays for fuel pump, thermo fans air conditioning etc, all of the gauges that you use inside the car, fuel, oil pressure, oil temp, water temp, uses all factory speed sensors, reverse sensors for the gearbox,knock sensors,vct, tps,water temp, etc etc when you install the engine in your z all you need to wire up to get it to run is 1 ignition wire, a fuel pump positive wire and a starter signal wire, using this harness will allow you to start and run the engine how it is, obviously you would want to wire all the temp gauges etc but is very simple to wire in Complete how to wire in is available on wiring specialties website Comes with brand new Castlemaine rod shop mount kit( engine mounts and trans mount to bolt into your 260z as well as a Brand new tailshaft to suit 5 speed to your longnose r200 So basically I have a full conversion to suit a 260z 2+2if you have a standard 260z you can just get the tailshaft shortened and will be ready to go I bought all this stuff bolted in, ran in on the stands then decided to pull the engine and do a body restoration, since then I have decided to go another direction in regards to the engine conversion as Heaps of spares I have receipts for everything Engine has 130xxxkm( bought from Skyline spares in Sydney) Receipts for engine,mounts,clutch,tailshaft, harness, plenum etc I have probably forgotten lots Priced at 4K Ring me on 0432669648 to discuss or dm me and I'll email as Many photos as you need (Still don't know how to upload photos) Thanks Located Newcastle nsw Andrew_L26 1 Quote
PriceyZed Posted June 30, 2017 Posted June 30, 2017 OMG if only my car was not in a million pieces Barra260Z 1 Quote
Barra260Z Posted June 30, 2017 Author Posted June 30, 2017 OMG if only my car was not in a million pieces Well you could buy the kit and put it all back together haha ? PriceyZed and gav240z 2 Quote
Dionysus Posted June 30, 2017 Posted June 30, 2017 If you consider selling the box separately shoot me a price.Thanks John Quote
Barra260Z Posted June 30, 2017 Author Posted June 30, 2017 Also forgot to put on the add I have a complete rb30 series 2 engine I'll chuck in aswell if someone wishes to do the rb30/25 build Quote
nat0_240_chevZ Posted July 2, 2017 Posted July 2, 2017 What gbox is it exactly? From what model /year of car? Cheers nat0 Quote
Barra260Z Posted July 2, 2017 Author Posted July 2, 2017 Rb30 mx7 transmission The rb25det boxes are he same length so if you want to use a rb25det box all you need to do is get the front yoke changed (should be around 100-150 for the yoke) and your ready to go Quote
Barra260Z Posted July 3, 2017 Author Posted July 3, 2017 Hey guys I have been asked by a member about what's invloved in bolting this setup Into a 240z Because I don't know will someone on here please Enlighten us to how/if it is possible Thanks Quote
Dan260Z Posted July 9, 2017 Posted July 9, 2017 Don't like to hijack the thread, but which hoses did you find work for hooking up the heater core to the RB? Quote
Barra260Z Posted July 11, 2017 Author Posted July 11, 2017 I used stock VL rb30 heater hoses and they fit perfect ( had the heater hoses on a spare rb30 in the shed) Engine has been sold Thanks Quote
Dan260Z Posted July 14, 2017 Posted July 14, 2017 Wow wouldn't have thought to try those, will give it a go. I assume the metal heater pipes on the back of the RB are given the flick? Barra260Z 1 Quote
Barra260Z Posted July 17, 2017 Author Posted July 17, 2017 Wow wouldn't have thought to try those, will give it a go. I assume the metal heater pipes on the back of the RB are given the flick? No used the rb heater pipes Quote
vspecrob Posted August 29, 2017 Posted August 29, 2017 Hi, Is the motor a Series 1 or 2? If it is a series 2, would consider separating the wiring harness? Cheers, Rob Quote
Barra260Z Posted September 14, 2017 Author Posted September 14, 2017 Hi, Is the motor a Series 1 or 2? If it is a series 2, would consider separating the wiring harness? Cheers, Rob Jump onto wiring specialties and have a look at there harnesses They do plug and play kits for Datsuns and a universal rb25 kit like I had Www.wiringspecialties.com They are worth the money for sure Quote
Administrators gav240z Posted September 19, 2017 Administrators Posted September 19, 2017 I'm interested in the mount kit? FYI: Not that it matters now, but new users cannot see their posts right away as an admin (me) has to approve them to ensure you're not a spammer. Should be fine to post from now on. Quote
Barra260Z Posted September 24, 2017 Author Posted September 24, 2017 I'm interested in the mount kit? Castlemaine rod shop will sort you out with a mount kit that's where I bought mine form so jump on their website and have a look Quote
