drifta1600 Posted March 7, 2017 Posted March 7, 2017 Got these new door trims today. From usa. Just over $600 shiped. There soo good! CBR Jeff 1 Quote
andyk_79 Posted March 7, 2017 Posted March 7, 2017 They're the same ones I got. Definitely a decent repro just watch the trim clip holes. Mine were all in the wrong place! drifta1600 1 Quote
Riceburner Posted March 7, 2017 Posted March 7, 2017 Looks to be good quality, I can see the difference between them and NOS. Quote
road rider Posted March 7, 2017 Posted March 7, 2017 Who did you buy those from? They do look good. Quote
GongZ Posted March 7, 2017 Posted March 7, 2017 Looks to be good quality, I can see the difference between them and NOS. Did you mean that you can or you can't see the difference Gareth? If you can see the difference - please explain. gav240z 1 Quote
Administrators gav240z Posted March 7, 2017 Administrators Posted March 7, 2017 Masonite backing is different to OEM, but as Andy mentioned I think the clip holes on these can vary making fitment a little painful. GongZ 1 Quote
mossy Posted March 7, 2017 Posted March 7, 2017 Looks like the door handle placement was restamped on the backing? GongZ 1 Quote
Riceburner Posted March 7, 2017 Posted March 7, 2017 Did you mean that you can or you can't see the difference Gareth? If you can see the difference - please explain. They fairly close in terms of the vinyl pattern compared to my NOS ones, like Gav said the Masonite is different but it won't be seen. I'd be very happy with them. It's nice to see some good quality reproductions becoming available. GongZ 1 Quote
andyk_79 Posted March 9, 2017 Posted March 9, 2017 Who did you buy those from? They do look good. I got mine through Fleabay: http://www.ebay.com.au/itm/Datsun-240Z-1970-73-Door-Card-Panel-Set-Black-Pair-Panels-NEW-754-/322430493547?hash=item4b125ae36b:g:mlEAAOSw0QFXDTWm and supplier's own website (same product and supplier) is zcardepot which a lot of people on here have purchased various products through: https://zcardepot.com/interior/interior-panels/door-panel-card-set-black-240z-1970-73-new.html Quote
aircobra Posted March 20, 2017 Posted March 20, 2017 i got a set from zcardepot that look the same Quote
geoffdy Posted April 7, 2017 Posted April 7, 2017 Looks great. Will check out that fleabay seller as I need to replace the door trims on my car. Quote
andyk_79 Posted June 19, 2017 Posted June 19, 2017 Want to update on my previous statement - the trim clip holes are actually pretty much spot on to the factory as i did a direct compare. The issue ended up being that I was trying to use modern christmas tree style clips. If you use the factory style clips where the protusion ends up offset from the actual cut hole then these will work. I'm ordering a set of the old style clips from msa now. gav240z 1 Quote
rajon1972 Posted June 26, 2017 Posted June 26, 2017 Do they finish the chrome strip by simply cutting both ends instead of a nice tapered finish like the factory ones? Quote
andyk_79 Posted June 27, 2017 Posted June 27, 2017 I'll take a look when I can, but from memory the ends are folded/rolled Quote
