They're the same ones I got. Definitely a decent repro just watch the trim clip holes. Mine were all in the wrong place!
Looks to be good quality, I can see the difference between them and NOS.
Did you mean that you can or you can't see the difference Gareth?
If you can see the difference - please explain.
Masonite backing is different to OEM, but as Andy mentioned I think the clip holes on these can vary making fitment a little painful.
They fairly close in terms of the vinyl pattern compared to my NOS ones, like Gav said the Masonite is different but it won't be seen. I'd be very happy with them. It's nice to see some good quality reproductions becoming available.
Who did you buy those from?
They do look good.
I got mine through Fleabay: http://www.ebay.com.au/itm/Datsun-240Z-1970-73-Door-Card-Panel-Set-Black-Pair-Panels-NEW-754-/322430493547?hash=item4b125ae36b:g:mlEAAOSw0QFXDTWm
and supplier's own website (same product and supplier) is zcardepot which a lot of people on here have purchased various products through:  https://zcardepot.com/interior/interior-panels/door-panel-card-set-black-240z-1970-73-new.html
  • 2 weeks later...
  • 3 weeks later...
  • 2 months later...
Want to update on my previous statement - the trim clip holes are actually pretty much spot on to the factory as i did a direct compare. The issue ended up being that I was trying to use modern christmas tree style clips. If you use the factory style clips where the protusion ends up offset from the actual cut hole then these will work. I'm ordering a set of the old style clips from msa now.
I'll take a look when I can, but from memory the ends are folded/rolled
