mossy Posted October 7, 2016 Posted October 7, 2016 Some of you have probably already seen this, looks pretty cool https://www.facebook.com/jenveydynamics/posts/1794171520858717 Quote
chris240 Posted October 7, 2016 Posted October 7, 2016 Yep, all over FB. I like it. Just wonder how they get around webers copyright ! Quote
Administrators gav240z Posted October 7, 2016 Administrators Posted October 7, 2016 Considering a good set of 44s all sorted and buttoned up will cost $3-4k it's not a bad deal. Remains to be seen how good they are though! Quote
mossy Posted October 7, 2016 Author Posted October 7, 2016 Would love to do it to mine, but I'm saving for some work on the head work on the N42 Quote
Agno Posted October 10, 2016 Posted October 10, 2016 Their website now has a placeholder for them, I wonder what the costs and lead times will be when they finally bring them out http://www.jenvey.co.uk/products2/twin-throttle-bodies/dcoe-heritage-bodies Quote
dat2kman Posted October 11, 2016 Posted October 11, 2016 assuming hard mounted onto intake mani, they shouldnt go out of balance. Should'nt be too hard to bore them out, and turn bigger diam butterfly plates! Quote
Agno Posted October 11, 2016 Posted October 11, 2016 My only concern would be trying to cleanly mount/hide the injector plugs under the carbs without exposing them to hot exhaust! Quote
dat2kman Posted October 11, 2016 Posted October 11, 2016 My only concern would be trying to cleanly mount/hide the injector plugs under the carbs without exposing them to hot exhaust!Nah!Waffle heat shielding will fix that. The plug sockets look to be on a longish lead, bring them out to under the airfilter over to inner fender. Assuming the leads have a decent heat proof cvering, they'll be fine. Quote
nizm0zed Posted October 12, 2016 Posted October 12, 2016 around $1400 pounds for a triple setup.Then you need all the EFI computer and gear on top.Not cheap, but consindering they are Jenvey's, they arent that expensive either. Quote
Administrators gav240z Posted November 7, 2016 Administrators Posted November 7, 2016 Datsun Spirit has some examples of this set up. https://datsunspirit.com/shop/itb-setup-for-l6/ Quote
