Pick up Northside 4054 area, may be able to post the switches if not picked up.
* 240Z daggy dash with rusty frame, some instruments, centre panel bits, glove box, restorable - $50 (picture below) SOLD
* 240Z good windscreen - $20 SOLD
* R180 K case 4.375:1 diff - $50 SOLD
* right side plastic sugar scoop - $30 SOLD
* 260Z large type brake booster, rusty outside - $50
* 240 and 260Z rubber strut tops - $10 each all SOLD
* cowl top, sits between bonnet and windscreen, great cond - $50 SOLD
* ignition lock with housing and keys - $35
* 240Z steering column - $30, steering wheel - $30 (steering wheel SOLD)
* indicator switch and column light etc switch - $40 each, $70 for both. (light switch SOLD)
* 240Z centre console - $40 (picture below) SOLD
* 240Z wiper motor and attachment - $25
* 260Z auto radiator - $50
Have some other stuff including 240Z struts and front hubs and brake discs, rear suspension arms, two higher ratio R180 diffs, two small SU carbs. PM or phone 3354 3204.
* bare 240Z struts - $50 pair.
Thanks for the enquiries blokes, as already indicated preference will be given to those who pick up. They also get the chance to have a look and be satisfied with their buys.
Pictures of the dash and the centre console, I hope. The top of the dash which can't be seen has six cracks. The centre console is not cracked but the two back attachment holes are larger than standard. Screw heads have pulled through?
I'd actually be interested in that dash if I had a cheap way of getting it to Sydney or Melbourne.
Otherwise any idea what it would cost to freight? I think it would be expensive as they are pretty heavy.
Gav,
I just come from det's place with the diff for Gareth.
James flett is here on Sat, he could bring it back, you'd need to talk to him about sticking it in his ute for you.
It's yours for free Gav if you can arrange a pick up. My donation to this site.
Mate I appreciate that I'm just trying to work out how to get it to Jason's place so potentially James can bring it back with him in the Ute. It would make a good experimental piece for dashboard restoration and I'll be sure to document my method so others can also follow - should they choose to give it a go.
Much like what I did with the Center Console and Steering Wheel resurrection threads.
Gav,
Thanks so much for your help Jason!
Gav there's already a couple of dash resto threads (one is a sticky).  Always good when people add their own learnings though !
I'm carless atm, i'll see if zed74 ( richie gragra) could collect it from 260det.
Hi mate,
I'll send you a PM.
All organised blokes? Great to see the Z helpfulness from Jason and Richard Graham aka zed74. Can someone let me know (phone 3354 3204) when the pickup is going to happen because I have to go out sometime this am.
I will be over around 3.30 - 4pm
Thanks to all involved to help get those parts to us in Sydney. Cheers.
