- Today
OdinZ started following Shakotan and Resto mods you wish you’d made…(and ones you’re glad you did).
- If you have to rebuild the L26, look at rebuilding an L28 instead. Depending on your budget for the motor, you can get a decent build out of Pearl Automotive Engineering (VIC). - Buy brand new Triple Webers from Weber Performance (VIC), and go straight for 45s. Even if you put the L26 in, and an L28 is an option later on, atleast you will have 45s already. - Yesterday
My Blue 260Z 2Seater
The Ratson
HS30-00171
The Ratson
The Ratson
- 1 reply
- 260z
- efi conversion
(and 1 more)
Tagged with:
Well, I finally got there a few weeks ago. I found it hard, I spent hours and hours, fitting refitting, remaking flares endlessly trying to get it right. My principle was "Done is better than perfect". First the flares, I bought three different tools until I got one that made consistently clean ones. This one was absolutely amazing to use, so satisfying to use that lever!....but only realised I'd missed the "bubble" in double bubble title, what a numpty. This one was awful or I was awful at using it The best one was this which was recommended on a lot of forums, making perfect flares is a skill (I do not have) but the tool removes pretty much all the guess work. Bending the lines drove me absolutely fcuking crazy, it took me way too long, too many tolerances to maintain in a tight space, I....disliked...this part. I did the bleeding with this tool which was alright, there's better more expensive ways, or if I had a lift a quick bottle and a hose way but I only had two stands and a jack so going around each point was kind of annoying. I pressure tested my lines with this before I installed each one so I know before I got it in that they were right. I've had her going up and down the street, the pedel is spongier than before, but the wheels lock up without it going right to the floor. But I don't trust them until I've had a pro look at them which is in its future. Next plan, it's off to Fulcrum Suspension for new Whiteline bushings as I do not have the time or tools for that job, 50% off install seemed good.... Special thanks to Joe, RichyRich and Enzo - I appreciate your time and help, thank you so much!
