- Today
OdinZ started following Shakotan and Resto mods you wish you’d made…(and ones you’re glad you did).
- If you have to rebuild the L26, look at rebuilding an L28 instead. Depending on your budget for the motor, you can get a decent build out of Pearl Automotive Engineering (VIC). - Buy brand new Triple Webers from Weber Performance (VIC), and go straight for 45s. Even if you put the L26 in, and an L28 is an option later on, atleast you will have 45s already. - Yesterday
My Blue 260Z 2Seater
The Ratson
HS30-00171
The Ratson
- 1 reply
- 260z
- efi conversion
(and 1 more)
Tagged with:
