- Today
- Yesterday
5 speed manual box (don't know what options exist) 280ZX / S2 bluebird '71B' is a bolt in. You can fit a 71C box from an S13 or R31/2 Skyline, but it requires mods and is not DIY friendly. You will also need to consider your diff ratio, as the auto diff is very tall. Subaru A/C system I've not heard of this. Another option is an AC system from a later 260Z is a bolt in, or you could go Vintage Air. Possibly a body kit (flares, side skirts, air dam, haven't seen a spoiler I like yet.) Each to their own, but none of the bodykits of seen for a Z improve the looks. Possible after market front suspension to eliminate rumor of bump steer. It's not a rumor and it gets worse the more you lower a Z. And it's a significant undertaking to deal with it, and none of the adjustable suspension kits on the market adequately deals with the issue. I suggest you speak to a Zed specialist - either Les Collins or Stewart Wilkins. - Last week
HS30-00171
The Ratson
The Ratson
- 1 reply
- 260z
- efi conversion
(and 1 more)
Tagged with:
