- Past hour
- Today
In our shop, from bare metal we Epoxy, then prime, then mask off the rails, stone chip the flat panels, then apply body colour over everything. IMHO This is the most professional way to go about the underside of a Z: - Yesterday
OdinZ started following Shakotan and Resto mods you wish you’d made…(and ones you’re glad you did).
- If you have to rebuild the L26, look at rebuilding an L28 instead. Depending on your budget for the motor, you can get a decent build out of Pearl Automotive Engineering (VIC). - Buy brand new Triple Webers from Weber Performance (VIC), and go straight for 45s. Even if you put the L26 in, and an L28 is an option later on, atleast you will have 45s already. - Last week
My Blue 260Z 2Seater
The Ratson
HS30-00171
The Ratson
- 1 reply
- 260z
- efi conversion
(and 1 more)
Tagged with:
Hi twosixtyzed I was wondering how you were getting on with this; thanks for providing the update. Its good to hear that you got there in the end. If it feels a bit spongy there might be a little bit of air in there still but it sounds like you are going to take it to a shop for them to have a look at. Did you bleed the new master?? No problems with the help...thats what this place is all about!
