tir33d
Members-
212 -
Everything posted by tir33d
Nice job, sounds good. Miss the induction noise! Funny how a 1 hour job turns into days. I myself hated the thought of pulling the motor again for the 4th or 5th time and supported the motor from the struts and dropped the cross member to get the pan off last time. So to ask a silly question.... I am sure I have seen paint inside motors that Pete has built, is there a purpose and is it something special (2 pak epoxy or something) yet he pulled back on the pan paint. I had my headers HPC coated and although expensive, does reduce temperature of the pipe if your worried. Go the orphan (280zx) lover.
The Restoration of a Monster: our V8 240Z
tir33d replied to Samfa12's topic in Members Project(s) Journal
Carlos was your parts guy, he is not really on here. Leave the battery where it is, if necessary build a insulating box, or alternatively get your exhaust manifolds HPC coated. I just did mine and there is a fair difference, they still get hot but temperatures seem much more controllable. I too must admit I don't mind the colour. If you need anything fabbed maybe I can put you in touch with my mate (lives in Barry) -
When you get it running you will have to join up with the Bathurst Light Car Club and give it a good squirt. They like V8 z's (or mine anyway). -
Eastern Creek - new motor not fully tuned, 3 track day old kumho semis, blown power steer (I don't know how people race without it - it killed me having to restle the wheel). 1.50.6 Cars everywhere, there were 40+ cars in our group with some very scary drivers out there. On a + I did manage to hold off a Audi R8.
As Pete mentioned, motor should be running on vacuum now, actually pulling the oil. The old motor used to suffer from oil vapour, this one will have an opposite effect. My mate and I both have the same system (although mine is running lmao). The gearing is what is supposed to work, it is a 50% reduction from crank speed and should work. You can change gears but we are only talking 2 or 3 teeth which would have only given me 7% - not enough. They say that a proper race motor can be turned over with about 20ft pound pressure, average street motor more like 60. The race motors have higher bearing tolerances to enable to free spin. Because this is basically a street motor that is why I had the pressure issue. Now for anyone who know me knows that I can "talk the talk" and my other racing buddies have been geeing me up. One mentioned that I will be lucky to get under 1.50 at the creek. Upon talking to a local who spanners on a super sedan he gave me some corrallation times between wakefield. Their super sedan does a 1.02 at Wakefiled and they say the short course at the creek should yield the same time. Long track they are doing 1.33-34. He thinks I should crack under a 1.40 if everything works. My oh my am I gonna be "talkin" tomorrow.
As you all may know I blew my motor due to running out of oil around corners. Only long term option was to install a drysump system. In the end I went with a 4 stage system from ARE (drysump.com). Now this is not for the budget conscious. Kit came with pan, pump, reservoir, breather can and drive pulley and balancer. Here is a pic installed onto motor, note how shiny my extractors are now (had them HPC coated). The new pan saves a heap of room, but creates its own problems, for a kit that is supposed to bolt onto a LS1 there are some major shortcomings. Had to trim half the starter mount and the rear fitting would have prevented it being tightened. Oil pump has been removed from the motor and blocked off, we are now using the rear point of entry behind the bung pictured below. This was another hassle, paid $100 extra for the fitting to take a -12 line and screw into the orifice, it arrived and was 2mm to big. Had a mate make one out of a bit of steel instead. And of course nothing comes with the kit to plumb so you have to buy extra gear. Total extra expense $1000. Was hoping to keep this all really neat, but reality of space changed some plans. Now we managed to get it all plumbed up and started and we were horrified at the pressure output of this little pump. At idle on minimum setting we saw 80psi on cold oil, 70 when hot, touch the throttle and your over 100psi. After seeking advice (thanks Pete) we came to the conclusion that the pump is too powerfull for a motor built to last more than 24 hours (most with this set up have much higher clearances). My fix, as I was unwilling to play with cutting or replacing springs in the pump unit, was to purchase a Petersen external pressure regulator. (the red thing below) This now has us set at 35psi at idle with a top at 70psi at 6000. While the car was on the hoist we also fitted some Techno toy caster adjusters. Now have -2.7' camber, 6' caster and 2mm positive toe. Motor is another 200000km job, installed new bearings, lifters, stainless valves and cam )230/230@110. Have some larger injectors to install prior to tuning on Friday. Been a mad rush but car is finished and ready 1 day early. Heading to Eastern creek on Friday (there is an open day for cams licence 2LS). Anyone want to give me a time to go for?? Little idle clip on hoist,
Is Kev the sort of bloke who puts up his incar footage? Or any footage from anyone
AZC Willwood setup, pads not retracting? Need help.
tir33d replied to sco_aus's topic in Brakes / Drivetrain Components
WOW. Promise I am not being a smartarse. So a "big" kit doesn't just bolt on. I would have thought this kit to be right. It sounds as though the disk needed more offset and the bracket made to suit. Were they designed to fit behind a standard wheel or something? I adapted some 6 pot VTTR's and we had to make bracket and bits and machine rotors down etc. Was worth the effort. -
Not many lobes left on that one. Motor was a throw away bar the valve springs and sensors. I actually don't trust myself to start this one, am concerned about oil pressure and purging the dry sump system(if necessary). I will get it all set and go to see my mechanic, he still needs to drop the tune into the car. MUST be done by the end of nov, we have the speed weekend again at Bathurst and I want to beat all cars (I know there will be a couple of open wheelers which are impossible to beat (they complain that the kink is bumpy at 310km/h +) Hindsight is beautiful, apparently 7200rpm on pretty well a standard motor doesn't help. Crank also had multi colours > hence the dry sump. Although expensive, it is the insurance necessary to enable a full new motor if this one doesn't live long. It was almost going to blow up straight away - luckily I put the intake manifold back on the other night when it was quiet, just as I placed it down I heard something, shook the hell out of it and out pops a bit of piston. Ended up with four chuncks about half the size of a fingernail. (when the bearing went on the crank that piston travelled further and engage a valve, this took a small chunk out of the top of the piston but obviously the motor kept going for a minute and the bent valve must of allowed it back into the inlet) Almost blew a new motor straight away.....
http://www.ls1.com.au/forum/showthread.php?t=148223&page=5&highlight=1000 look on the last page or two, there is a vid of a GTR in car and couple of pics of the VL
Motor is done, new bearings, lifters, stainless valves, 232/232 @110 cam, light port work on heads. ARE 4 stage pump (still waiting on an fittings from usa). Had to modify one engine mount, moved my brake distribution block to wheel arch rather than chassis rail. Fitted a bias valve to rear brakes. Start throwing it back in tomorrow.
The temora sprint was on last weekend, I couldn't attend as my motor is still not back in. Thought I should let you all know a VL with RB26 won. 297km/h in 1000m. apparently 700kw. Next 3 spots were by street driven (drove to and from event from Sth aust) R35 GTR's (about 270km/h). Go Datsun........................
You only get what YOU pay for. Me, I started with a $1900 280zx. As the bug kicked in I found money to build my car - its not registered and never will be, but now owes me probably $30k. Shit theres $10k in brakes and oil system alone. Am I rich? HELL NO! I am now 39 years old and its only in the last 5 years that I have been able to afford to indulge my car passion. As someone previously said, do your engineering and have fun with your 253. If or when you blow it up replace with a 308 and if you can find a cheap one get a 355 stroker (a friend just got one for $800). The reason everyone had a shot is they were trying to guide you to get the best bang for your buck. Often the easy bit is the motor, the other bits add up and if you have to do it twice it costs you twice. Remember you still have to do your gearbox mount, figure out a clutch and master cylinder, engineer a tailshaft, a loop for your shaft, extractors and exhaust etc etc. Personally I don't really do burnout cars although my track toy would be outstanding at the job. The reason everyone we having a shot is that it will get more expensive than you plan so a L28 with less engineering is an easy option, easy power is from a LS1 (my track toy was a $1000 motor witha cam and springs and was at 400hp atw before I blew it up). On another manners note, there really is some nice people here with a abundance of info. Some have bigger budgets than us all, others do all their own work over time. The old 253 boat anchor bit got you going I can see, but don't let a bit of stirring get to you. Oh and my track toy runs a CIG locker (welded up R200 diff). Good cheap way of doing it if your still going ahead. Mines lasted 1.5 years with regular oil changes.
sliced down thru valves. Ultimately showing you have shaping room only, take too much and your gonna loose. prob only 4mm between water and ports.
Just so happen to have a couple of sliced heads. Not alot of room for error. CNC is easy and reliable. Don't be fixated with rwkw. As most know dynos are different everywhere.
Honestly haven't touched it. When I bought it I was in the middle of a expensive upgrade on my track toy. Have since blown up my track toy so funds are tighter. Car doesn't run, think its a issue with the elctronic maf. Motor starts but then dies after cold enrichment. Needs to be trailered.
damn wrong tab button
As some of you would know from my posts my life changed recently. After 14 yrs of marriage and 10 years of no contraception, finally my wife and I have a little (very little) bundle of joy. On Sept 8 we welcomed Shelby Louella Ryan to the world, born at just 1.890 kg (or 4 pounds). The little tacker has gone from strength to strength, never lost any weight and came home from the hospital after just one week weighing just under 2kg. http://i1011.photobucket.com/albums/af236/tir33d1/photo.jpg Now although I had the final decision on the name, my wife Bec actually suggested it first. Poor girl, not only is she named after an all time great in the ford world, but she also has SLR as her intials. Ford > Holden........ Poor thing. But I digress, I wonder if there is any room on this Z website for a AC cobra build up. Gotta build my girl a car that is synonamous with her name I think.
$35 for braided lines - did they just wrap some red cotton around them. I think the best I have had is $196 for two lines.
http://www.viczcar.com/forum/index.php/topic,8218.0.html With my little girls arrival and her naming (Shelby) I don't think this car will turn into my idea of a street registered LS1. $1000. Car is at Blayney near Bathurst. And to sweeten a little I could take it half way to Qld. Say Moree or Coffs
You know i have done this conversion and you still end up shelling out over $600 (sometimes 800-900 if you put some new braided lines also) and I don't think its that great. I could never find a decent pad as all I could seem to find was a 4wd pad. There are a few people on hear that have used alternatives (AU falcon and commodore). I think this would be a better option as the supply of bits is better.
Careful now Tim, if you go for a big cam and you want to shave your heads you will run into PTV clearance problems ( making it necessary to fly cut your pistons). My VE ute runs a 220/220 cam, it is a nice mild cam which put 320kw to the rollers on a dyno. This cam enables you to use 6th gear down to 80-85km/h, but still pulls strongly up to 6300 and carries to 7000rpm. (Also remember VE has great heads and higher compression and 6.0L ) My old cam in the 280 was around to 228/232, was a good cam but never road driven. My new cam I believe is a 230/230 with about 600 lift (old cam had nearer tto 650 lift and we thought that was being a bit hard on the valvetrain gear.) With this new cam my mech has had it in a drift car bouncing on 7000 continously and still makes easy 300kw at the wheels. I know you love it and seem to have the funds, but unless you are going to do a mini rebuild maybe you should lower the cam specs. A torquey cam is still very driveable, and much more usable. A big cam mean you have to rev it to get it. Hills mean gear changes. If you go to big at the track you will find your changing gears more often to keep in the peak zone of the cam. I much prefer a cam that will still work down to 3000rpm say, as opposed to a cam that will only scream from 4500. Are those cam specs a TK Cam? (Turbo killer).
