tir33d
Everything posted by tir33d
  1. LOL I have 1 5/8 primary 2.5 twins to diff then into a single 3 inch edelbrock rear muffler. It does a bit, but not much. I had a pair of 600mm hotdogs/resonators but we decided to leave them off. Lucky you didn't change your exhaust before your cam. Even my ute sounds heaps crankier and louder with the cam. How big is your cam, has it been tuned, how much power and most importantly how is your diff (I assume you have a R200)
  2. Well, my poor little dato has been fighting me all week. Little jobs turn into half day marathons, and worst of all little hiccups have held me up also. One major hiccup was in the form of no oil pressure in the motor. After priming the oil system several times and in several different ways we came to the conclusion that we must have had an issue at the sump pickup. So rather than pulling out the motor and box (and exhaust wiring loom, clutch slave, radiator etc) we dropped the crossmember with the motor supported on the towers. Upon inspection I found that I had pinched the oring on installation of the pickup. So back together again, then about to move off the hoist and I noticed that the master for the clutch was loosing some fluid with each clutch stroke. MMMM. Box out again, found that bleed line I had made wasn't tightened enough so was leaking. back together again. Anyway, oil pressure good, clutch pressure good. Motor starts and idles roughly as the cam is feeding way too much fuel. Booked in for a tune on Monday morning 9am in Sydney, then I might try to convince the wife to let me go to Wakefield on Wednesday for a day of sorting. Then on Sunday 29th we have a Hillclimb here at Bathurst. Hopefully I will take some more photos tomorrow. I will also try to get a little video of the dyno on Monday. With the current tune and cam it sounds like a full on stockcar, I know the tune will calm it down a little, but I hope the sound still stays, it sound so horny I tell ya!
  3. hope that works - if all comes to plan this is what I will be doing with it in 2 weeks.
  4. I had the local clutch joint make me a bleed line about 8 inches long which hangs ourside the box for bleeding as I know that even on my VE ute that its a pain - oh and they made it in braided line (just to take more money out of my wallet). That master is actually a $30 unit. I have a limited pool of knowledge to tap where I live and was advised that a shorter cylinder was unavailable by the local supplier), As for the sensors they are all connected bar the oil pressure - this was left off by Steve at Killa's as he knew it was a track only jobbie and I was going to run mechanical gauges. And although tight down there I can still disconnect wiring if necessary. As for the exhaust they are 1 5/8 primary to a 2 1/2 four into one which we are going to meet together prir to the diff to 3 inch for a single muffler at rear. I would have liked 1 3/4 primary but space was very tight on drivers side. Notice how we had to mount one coil pack ontop of the other for clearance even on top. I really should have cleaned the welds up a little to make them look better but they are a really good job. The cam is in already, and we have installed PAC extreme springs for safe 7000rpm running. I'm a little anal about the spring thing also (just replaced my springs in my ute for the second time in 65000kms) The fuel system has a pump in the original location which I thought initially was a 044 bosch, have since figured it to be a smaller unit but it was still up to the task of feeding the previous turbo 6. Feeds to a swirlpot on old battery tray, out of surge to 044 bosch, non return valve into 8mm to standard fuel rail, ends removed from rail at firewall and joined via a malpassi regulator, purge to surge tank. Hopefully this will work, we did try today to do a basic deadhead system with old style mechanical reg after 044, mmmm lets say that we changed plans after that. Thanks for the offer of the wiring but hopefully it should all go, I had Killa's do the kit and wire it so it only has what is necessary. So looking forward to driving this thing......... Phil
  5. Two weeks later and I missed my deadline. My plan was to be running and using it at Wakefield yesterday but missed out by about a day. Still not running just yet as we have changed tack on the fuel system. Exhaust also needs to be finished from the collector back. This was the clearance issue at the master cylinder for the clutch - you will see the fix in a sec. Straightened the original fuel lines and re-run them across the firewall, the fuel system uses the original pump from the rear to pump up to a surge can at the front in the battery area. someone asked about tunnel clearance - my gearbox cam back a little further than planned, need to give myself an extra inch or so The magic master cylinder fix - a pedal lever system from a hyundai mounted so as to leave the master inside the cabin. You can also see my attempt at strengthening the dash area One of the spacers / plates made for the tailshaft mount - this tailshaft now has replacable uni's. Gearbox mount with tailshaft loop incorporated into it. Motor in and almost ready to go - radiator from a HZ holden with outlets moved to suit. Amate of mines first attempt at making extractors - I think he did a great job. I need to clean up some wires but the finished dash. Isolator, main ign switch, switch for second fuel pump (after catch can) start button. What else do you need? My rollcage - performed at an earlier date. Heres so bits I removed earlier LOL Hopefully tomorrow I will get a video file of the motor going!
  6. Sorry your right, its the master that needs replacing. The difference between the VE box and earlier models is a slightly shorter input shaft and a slightly better gear set. I searched ebay for over 2 months hoping to get a T56 for around $1200. Every box that I bid on ended up going around $1500. In the end I got a brand new 6 speed for $2000. So I put the new box, along with a new textralia Z grip in my VE ute and pulled the old z grip out to use in the 280zx. The main issue to be addressed with the shorter shaft is to ensure you have a bearing right at the end of the crank as the shaft only enters the bearing by about 10mm. Also the VE slave cylinder has shown to be a weak link in the commodore so a little tweaking and you change it to a VY style slave cylinder. This has been done in both my ute and the datsun. As for the manifold I plan on replacing eventually with a single plane and decent throttle body on top similar to a four barrel. The cam 227/234 @ 112 with .640 intake lift and .595 exhaust should wake this old motor up nicely. The motor actually has over 200000kms on it but was run down the strip just prior to removal from a VX commodore (with a lot smaller cam it still managed 11.7.) An idea on costs - initial motor - swapped for $1000 worth of tyres gearbox - $2000 + $200 shipping from adelaide cam, springs, new oil pump, timing chain - $1500 2nd motor - bought for all ancillary parts and sensors - $1000 coilovers - (more on that one later >> tried to get some K-sports as they now list a part no but arrived on Friday and they didn't have adjustable tops and the rears are wrong) - $2000 clutch - $1200 shifter mechanism - $300 oil pan and remote fitting - $780 computer loom strip down and rewire - @$600 Still need to get some injectors and a tune on the motor - @$1000 + + Lots of bits also here and there but as you can see, even doing it cheap gets bloody expensive. Looking back over those photos I think the first job today might be to clean up that engine bay a little.
  7. It fits well Had to get a rear sump Nice fit
  8. Mentioned my plan a few weeks ago on here and now things are happening. Wallet and bank account on a manic decline. The plan was to do a conversion for under $5000 and just have something to flog the hell out of on trackdays and club duties, well the $5000 has just gone past $10000 and I think I still have a couple of grand to go. The plan is to have this running by the 13th August for a track day at Wakefield, currently I think I am still looking good. Looking for 400hp at the treads, reasonable size cam, 6 speed gearbox from VE commodore, CIG locked R200, hilux brakes (for now), fully stripped interior (including air con, heater box etc) half cage (but will probably weld some front legs also). A friend of mine is helping me with the fabrication of the mounts and although a little tight, it looks like it was meant to be there. He does V6 conversions so has some of his own ideas. The motor mount uses the old aussie holden V8 mount, hers a photo while still in process. [/ihttp://i1011.photobucket.com/albums/af236/tir33d1/DSC01180.jpgmg] Currently have the motor mounts done, gearbox mounts tomorrow and hopefully finish fuel system. New clutch slave necessary as the stock one - facing the motor is going to be too close. Going to have to run a new throttle cable. Really enjoying having a project happening, although I now cannot tell the wife about any more purchases as I am not in the good books. It is kind of a shame I made this a track car as it would be a hell of alot of fun on the road. I will try to keep you all updated.
  9. SOLD... Yep it is a great buy, and seems to have gone to the right bloke with the right purpose. Thanks all Will let you know how I go with the LS1 conversion
  10. Avid reader, rare poster, big ideas man. Hey some may say im silly, (actually most of the town where I live) but I am goin to remove the L28 from my 280zx and replace with a LS1 and 6 speed. You will get: L28with factory turbo manifold xr6 intercooler new turbo (off fleabay rated at up to 600hp) 5 speed with a nasty paddle clutch running the larger flywheel pressure plate combination wolf 3d computer V3 boost gauge and electric boost controller all piping to suit (including blow off) Head just been serviced, new timing chain and gear new water pump Ok a little history, I bought this car of ebay 18mths ago as is with turbo, used it as a run around for a while then took it to Wakefield Park racetrack. I also own a VE ute that has a cam and makes about 320kw atw. Me VE does 1.11 with alot of money spent, my dato does 1.15 with no money spent. Good strong little motor with really sloppy handling. Anyway, my V8 friends have all embarked on the track only car concept so I have decided to do the same. Last outing at Wakefield I push the limit a little far. I eventually blew the exhaust side seal on the turbo, we removed the head, no internal damage, no head damage but had it all serviced anyway and a couple of exhaust valves replaced. Replace the timing chain and put it all back together. Running again now but I have now assembled all my bits for the conversion so I am keen to start. OK what you need to know. Although all there, the computer system running the turbo is old and hard to get someone who knows what he is doing, I would suggest to get it right you would be better off to put a new computer at it. The current tune is rich - not dangerous. It produces good power, but there is obviously heaps left. Some of the pipework it a little average to look at, but a sand and coat of paint will fix this. the clutch was bought as a track only clutch, standard clutch slips immediately. The clutch is nasty, engages very solidly and honestly not road friendly. Located near Bathurst NSW, am able to assist with freight. Currently still in car Ok open to suggestions was thinking $1500 was more than fair! I have spent at least that on and around the motor in the last 12 months. thanks Phill 0402115201
  11. Hey everyone, new here but have a bit of an idea. I am the lucky recipient that bought that 280zx from Sydney of ebay 6 weeks ago. The red one with the turbo. item no - 260375214909 Anyway the prob with not starting was rectified by de-wiring the alarm. Had it running within 1 hour. Gearbox needed replacing - done that with a second hand unit. Replaced 2 tie rod ends and rego was done. the car initially only made 6psi but has a boost controller as well as the wolf 3d. I thought there was something not right so gave to an auto elec to get him to go over wiring. He rewired most of it and found the Throtte Pos switch to be faulty. When he gave it back he smiled and said that he wished he had it. Well now I can wind up to 20psi of boost into this little motor and doesn't she boogy. I also own a VE 6litre with 320kw's at the wheels but I think this would give it some curry. Needless to say the clutch doesn't like this boost level and is slipping under anymore than 10psi of boost. So I need a clutch. I made the step with my VE of going to a button clutch for the abuse factor. Manufacter encourages clutch kicking the car on the drag strip. I found a similar clutch on ebay US, 6 puck with pressure plate $180 US including postage. item no - 350190710314 I think this clutch will be up to the demands and I am aware of the issues with button clutches, ie shuddering. But what will I do about the gearbox. It is showing signs of stress already. Although I bought this car cheap I think I may spend some money on it and make it into a road registered track car. I currently use my VE and it scares me to think of the cost if I put it into a wall. So questions will follow about, coilovers and suspension bushings and also brakes. Hello to all and thanks for any input Phill
