Sirpent
Everything posted by Sirpent
  1. Sirpent
    [NEED] 260Z Dash
    Get it re-vacuum covered by the Dash Doctor. All 260Z dash's are the same, no difference between a 2 seater and a 2+2, that goes for all structual, equipment and features from the firewall forward.
  2. Hey congratulations Mick, Considering the turn you took in 2010, and where you have the car up to now, all I can say is great work, that 2nd pic of the drivers rear 1/4 with the flare just looks magic, once it has color will look damn hot ! You are truley one of the quiet achievers on this forum, well done ! Cheers John
  3. Thats Brilliant Scoota ! Should drop it into a spread sheet and post it in this thread. Cheers John
  4. This is tragic, However looks like the Pacific ring of fire which stretches from the South Pole via NZ all the way up throuh Japan etc is very active which means one thing, the Australasian or Pacific plate is on the move, if the Hawaian Islands flair up with new volcanic activity then the tip of the pacific plate is likely to see the next activity as it pushes up against the Atlantic plate, that tip is California, and the San Andrea fault line is the boundary. Id be worried if I was in that part of the world in the coming months.
  5. OK, From what you described without actually seeing it it sounds like VERY poor surface prep before the material was laid down. To use an analogy as far as surface prep, imagine freshly painted or polished paint work and then pouring water on it, the water beads and then accumulates, as you put it then streams. Now imagine very dull oxidised paintwork which hasn't been polished for years, water sprayed on it in the same manner develops a film more or less evenly across the surface. Unless a surface is properly prepped, the same effects will occur, whats happened in your case is that the sprayed material has failed to bond to the surface, as the solvents evaporate leaving only the material they contract and a grazing as you put it effect occurs, these are actually fractures in the non binding area's. The only way to remedy this if I am correct is to take back all the sprayed material and start again. As far as 2K etch primer, this is only used on bare metal, I cant see why it would have been used in this case so I'm unsure what you and Salty are referring to. Any 2K product properly cured shouldn't present a problem if you are using acrylic products over the top as long as high concentrations of solvents aren't immediately applied resulting in destabilisation and solvent burn. I found this EXTREME pic on the web, is this more in line with what you are referring to? Cheers John
  6. Gav I know this may not be a parts supplier, however in my travels on the net I came across a listing of parts with Nissan part numbers and also a plethora of pic links for the listed items. This may serve as a good search media for obscure parts for members. It wouldn't be bad if this could be incorporated somehow with the links into our database, just an idea. Cheers John http://zman.knocklein.com/_NUMBERS/mid.htm
  7. I agree with you totally, but my post wasnt a means of trying to ramp up recognition for myself if that was what you were reffering to. For a forum with 2000+ members, where I doubt more than 5% support the site financially, the idea of the Pledge was to attempt to ramp up some support. Cheers John
  8. Think Mick answered it already but Im happy to take a pic of the spare I have with the cap off.
  9. Current shape Celica seats. Comfortable contemporary good size and also pretty cheap at the wreckers. Cheers John
  10. Hey lukas... Great intro, welcome, and that pic with you and the car "A boy and his toy" thats a keeper buddy, look back on it in years to come. All the very best with your build. Cheers John +1 Karma
  11. Thanks REV, Im sitting here doing NUDDA anyway, and I figure when the time comes I will have 2 options if I dont do this now, do it then and hold things up even longer or just dump it all back in and then hate myself for cutting corners, One thing Im doing is keeping an account of all of this in pics, that way when i insure it and something happens, the photos are there to prove whats the cars worth. Cheers John P.S. Hope you find a Z soon Dave, Im sure there is one waiting for that special attention you are sure to give it.
  12. Hi Crew Just a few small updates............. "Das Drehkraftmonster RS32 AMG" have had confirmation from the shipping company that my supplier has cleaned and bundled everything up to their requirements, pick up will be in the next few days and they seem to think I shouldn't have any drama's with Australian Customs or Quarantine services once it lands. Chassis engineering Paul emailed me advising that he has been on the phone to the authorities with a number of questions regarding the build, they wanted the full emissions complied with as per a C32 Benz apparently, he counter argued with them and apparently won the argument, he is still to fully brief me but apparently I will be able to dump any emissions gear off the C32 that I ca, apart from the Cat's I'm not sure what else there would be that wouldn't interfere with the engines proper function, guess its one of those things I will suck and see. Refurbishments. Having overhauled the Weber's, and not wanting to do anymore body wise till this engine chassis deal is underway or done, I decided that I should start refurbishing some of the things I'm planning to put back into the car, so I stripped down the entire Heater / AC assy last night and spent a good part of the night and this afternoon refurbishing it. The Heater core and AC core where in surprisingly good nic, the AC core just needed a de-greasing and came up trumps, the heater core seems good but I wont be risking anything and will replace it as a precaution. Cleaned all the housings which were putrid, almost every bracket was partially rusted, the galv on these parts from the factory was simply useless, so all were stripped back to bare metal undercoated and enameled black. Cleaned and checked all the electrical looms, valves etc and all was good, the only other part that needs to be replaced is the heater valve and associated heater hose, the valve or "C0CK" as its known shows signs of slight leakage at the rubber valve seat and seal, I wont take any chances and will try and hunt one down. TIP: Before stripping one of these units down, take photo's, I got stuck a few times looking at a part trying to figure out what the F*CK ! So as soon as this is done vacuum packed and stored away, its the dash assy next. Cheers John
  13. Well done David ! If you hadn't come up with a solution I was going to suggest a Ford Probe Clutch cylinder, very short and totally encapsulated deriving it's fluid from a remote reservoir source, in the Probes case it's the Brake Master fluid reservoir. But again your work is as impressive as ever, cant imagine what pleasures I will be faced with when I eventually start toiling with mine. Cheers John
  14. Do you have a camera on your phone? Salty, how is he havnt seen him here in a long time ! Is what you are referring to look like crows feet as per this pic? Cheers John
  15. Post up some pics so we can get a better idea.
  16. Hi Buddy Years ago my Tach just stopped functioning and I took it to Speedscreen who reapired it Cheers John Their details are Speedscreen PTY LTD 151 Mt Alexander Road Flemington VIC 3031 Phone: (03) 9376 0714
  17. MMMMMMMM Nice Pete, but we still have to sort out that nose, I haven't forgotten. Hows Amanda and the little one doing?
  18. Hi all Id just like to congratulate Simon "MaygZ" who is now the proud new father of Triplets and condolences on how this acquisition may strain his relationship with his wife. Remember, she may scream now, but they will purr for you endlessly across the many miles ahead. Cheers John
  19. Dimitri, Somehow I think you may have stumbled across a cache somewhere, and also, I know a Zed guy who has a 302 Cleveland set up that came out of a Zed that was totaled by a stray cow, PM me if you want his details. Cheers John
  20. Welcome Shane, They just keep coming out of the woodwork ! All the best with the Z, love those 45's shame it's not a quad set up. Cheers John
  21. Open the listing up in Explorer or Firefox Go to the address bar, start at either end of the address hold down the left mouse key and scroll across the address. Once the address has been highlighted, press the right mouse key and select copy Open up this page and select reply, click in the dialogue area with the left mouse key, then the right and select paste
  22. Alan Maybe cut and paste the link?
  23. Hi Used to have one of these in my Zed, and I have a spare dizzy sitting around. Cheers John
