As you can see from this photo it has been vaccume leaking from number 1
This is because the manifold has been fowling on the thermostat housing.
You can see the mark it left in the aluminium in this pic
I ground the manifold down to stop it fowling and then fitted it back up.
Unfortunately it is still running bad and popping from the carbs.
I can not get the carbs balanced. With the linkages disconnected,
The front carby has the highest air flow even with idol screw all the way out.
I can't get carby two and 3 to flow as high as number 1 even with the idol screws all the way in.
I thinking that it must still be leaking air some where.
I will get a new manifold gasket during the week and see of that helps. I am hoping I haven't bent the manifold screwing it up on the thermostat bolt.
