Showing content with the highest reputation on 09/28/2023 in all areas
  1. Stinkbug
    Efi turbo L26
    Very happy to report that I got the engine compliances today. 2 days before the emission testing exemption expired. happy days!
    2 points
  2. C.A.R.
    HS30-00211
    With the rear quarters clamped in position, then next thing we had to do was fit the rare spares door skins. Rare Spares has a sticker on ALL their panels stating that: "This is panel is only a vague approximation of an OEM panel and shitloads of work will be required to make it fit correctly." Paul clamped them onto the rebuilt door frames to check fitment and... well... there were issues. The door handle recess was 'low' in one skin in relation to the body line. The door handle recess in both skins was 'sucked in' when a ruler was run across the body line. The handle holes were in the wrong spot. The upper body line was not sharp enough or not there at all... Paul spent 3 days rectifying these issues - we worked out it would have been quicker to make new ones from scratch! But eventually they were fitted to the frames (after I removed the e-coating): Before the skins were fitted I Epoxied the insides of them and applied a coat of KBS Rust Seal to (hopefully) keep them rust free forever. We are aiming for a 5mm panel gap and it appears we will succeed in obtaining that measurement.
    1 point
