So been busy trying to sort our all the fuel, brake and turbo lines on the car and fitting the front and rear calipers and have come across a issue with the rear set-up.
Fuel, brake and turbo lines all look good and hidden, quite happy with the work.
Im using the SW caliper kit to suite the rear R33 GTST set-up. The kit has been mounted well and the disk, caliper fit and rotate well with no issues.
So the issue I have is that when we put the disc on we noticed that the centre hub is flush with the disc and that when we put the wheel on the hub does not extend into the centre of the wheel. Its just hollow and the weight of the car will be sitting on the studs and not on the hub, causing the distribution of weight to be on the studs.
Wheels are Watanabe 15 × 8 zero offset, Tyres are 225/50/R15
Issue two is when we put the wheel on the wheel wont spin as it catches onto the real caliper. We can sort of solve this issue with spacers but I might run into another issue of having the wheel sticking out and hitting the inner guards when hitting a bump.
I might need to machine inside of the wheels but I really dont want to head down this path as they are brand new wheels and I dont want to damage them in any way.
Has anyone in the group had this issue? And what options are out there without changing my wheels
Youhan
