Been chipping away at this.
Needs to be registered in Vic before tear down and shenanigans can begin so needs a RWC. Biggest issue was the rear main that was pissing out so went to remove the trans which requires the removal of the trans dipstick tube that has a large tube nut attaching it to the side of the pan. I went do undo this and it mangled thread as I was undoing....damn. Goggle search in the Volvo world says this is V common and not to undo them unless you have to......
Two trips and phone calls secured the right second hand tube from Berry Motor Group in Mitcham. Old rear main was well and truly munted
Next up were the front seats, the foam and pushed through the frames and was not supported in any way so had to rebuild the foam and put new webing in the backs and fix the bases. Came up pretty well considering.
Had to make the old girl look more respectable so needed to tackle the really badly oxidised paint
Reday for RWC next week
