Hi guys,
I recently picked up an un-finished 2 seater 260z project car off a mate. The car has already been stripped and had most of its rust removed by the previous owner. The chassis is straight and rust-free so the base car is a good place to start.
There is a fuel-injected L28 engine, and manual gearbox. The engine is in fine working order apart from the need to replace a fuel pump. There is also a trick cam, extractors and aftermarket exhaust system.
The car came with a set of lower springs and I recently picked-up some front and rear swaybars.
At the moment I am hunting for a few more bits and pieced before finally she is ready to be prepared for bodywork. The main ones are
-bonnet
-bumper bars
-repair section for rear tail panel where rust sections have been cut-out of each corner
-Windscreen
There are many other bits I will need to collect along the way, but getting the body fixed will go a long way to getting this project happening
My first goal is to get the bodywork cleaned-up and ready for a re-spray. While the engine is out I will be able to clean it up and replace old hoses.
My goal for this project is to create a streetable yet fast sportscar that is not far from stock and captures the '70s muscle car feel.
Full album here:
http://s986.photobucket.com/albums/ae346/ricardo361/Rics%20260z%20restoration/
You have some fun ahead of you. Many of us know first hand. Keep us informed of the progress. Good luck
i love seeing projects like this. It makes me feel better about mine
It sure looks as though the last owner knew his way around a welder  ???
Keep us posted ill be watching
Welcome! My first 260Z wasn't far of your one condition wise.. took a while with the body but eventually turned out sweet!
I think they have a cockatoo problem in that area....
Good Luck..a lot of work
A 260z....Muscle Car feel????
Haha, well maybe I worded that wrong. It has to feel like a 70s car, but obviously drive nicely. Not like the plastic rubbish we get in cars these days. And forget the monaro handling and braking!
  • 4 months later...
Quick update on how everything is going here..
Recently I collected the last of my rust repair sections, along with replacement bumper bars and the fuel filler panel/assembly.  The car is now just short of a bonnet and will be taken to the panel shop in next two weeks. Joy!
WOW!!!
You move pretty fast.  To the panel shop for repair or are you up to paint already???
