Mick,
I got my Tremec 5 Speed TKO600 from Mal Wood brand new for $3,500- or something. All was good when dealing with them and shipping down.
  • 2 weeks later...
  • Replies 159
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Well I have replaced gearbox will rebuild the old one over next few months Rebuilt diff has full 6 clutches this time Wow car just launches now looking forward to hillclimb next weekend see if I can go quicker
Just need to put some tyres with rubber on that will help too
Mick
  • 1 month later...
Off to powercruise this weekend anyone in Tassie look me up happy to take anyone for a ride around track will be cruising every cruise session
Done some mods for weekend Got my 17" Simmons painted and new outers on So now can keep 18" simmons for track tyres
Extended the grille adding 3 slats to fill the gap to spoiler
Removed bumper bar and made new mini bumpers from old bumper bar
Took the bug catcher off and put other bonnet on Made up new cold air intake
Mick
I like the new look Mick.
Does the new intake make any difference? And did you make it yourself.
I won't be able to make it to powercruise this year as my brother is getting married :-\.
have fun.
Regards Scott.
Yes Scott made intake myself Not sure if it has made a change sure sounds like it sucking more air and first drive last night felt bit crisper Would think it should flow better than bug catcher
Sorry to hear you wont make it on weekend looks like weathers gonna be good and there letting us in Friday night so more cruise time Saturday enjoy the wedding
mick
Looks great Mick. You have done a massive amount of work on developing that car. Keep it on the black stuff and enjoy.
I notice you didn't go for the G-Nose. Keeping it close to traditional. Great car.  :D
  • 9 months later...
Wanting to do a the Mt Poatina hillclimb I was told I need a cams approved cage So I bit the bullet and pulled my car apart major job as much of the carpet was glued down pulled old cage out Bought a new Bond roll bars half cage and set it all up got local workshop to weld it in
Then while car was apart thought id lower seats 50mm fit some dynamat to stop noise and heat  and put new harness in
Got it all back together last week in time for Barrington hillclimb Drove up on street tyres with sticky tyres in back and on passenger seat so no trying things out Was smiling loving new lower driving position plus added leg room from getting full seat travel now roll cage brace is in back and not in main hoop
Was perfect day sunny and dry Last 2 runs at barrington have been Cn the wet What a shock when I did first run no traction ok 2nd will be good once tyres get some temp no better didn't get any better during day my best was only .25 of second quicker than best on a wet run earlier in the year Car was just bouncing around and not getting any grip
Im thinking new bracing from roll cage must  have stiffened back end up and that with 440 lb springs im running in rear and 380 in front is was just too stiff
Off to Symons plains tomorrow for a driver training course so ive fitted 250 springs all round see if that works better has left car sitting lower as well so one bonus already
Getting cage and log inspection tomorrow as well so hopefully it gets tick of approval to make the effort worthwhile
Hope it all comes together
Yes Mick , they say that a good cage will change the way the car handles. Hope you get it sorted. I would have just softened the rear to start with. But you can try stuff on the weekend.  Good luck.
Bondy had the same problem's when he re-did his cage pal, might be worth a call. I think he went lighter with the sway bars?
If I was you I wouldn't change a thing....
Thanks Hodgo ill take that advice im sure your telling me for the best reasons Lol
But I already changed the springs and car felt much better at Symons today putting power down much better with the softer springs even on my old ku36 semis Hopefully a50 will grip even better at Highclere Might still buy some 280 and 336 springs and try them
Roll cage and and log book ticked off by inspector just need to send application off now
So next weeks jobs change heads to better flowing ls6 ones pull my new 1"7/8 extractors off and send them off for ceramic coating
Mick
Geez Mick you are doing some big work.
I have 3600Ib springs in mine all round. My cage made a big difference but also the ride hight. From memory you might have been running a bit highter then me. Might also help with handling. Mind you my car is more for road than track. I am sure you already have beefed up sway bars.
Will be awesome to see your car again at the Feb'15 Tassie Trip.
3600 lb springs, lol.  We know what you mean. Defiantly a road car, can't remember when you had it on a Victorian track Craig.  Haha
As the stiffness of a chassis is increased so should the stiffness of the springs used eg the standard S30 chassis is very flexy so using heavy springs only causes the chassis to flex more and become one giant, soft spring which can't be tuned. So choosing spring rates depends very much on how stiff the chassis is. And then there are the dampers..........
Better shut up, lap times are what counts so..........but I love the theory and application of suspension theory so forgive my mini rant, please :)
Yeah, mine caused mass oversteer on exit when we put the cage in. Went from a 23mm rear bar back to a 16mm rear bar and it fixed it.  I'm only running 200lb springs but I generally like a softer setup.
I think im running 19mm rear and 22mm front bars Struts are bilstein all round getting old but done very little work Chassis is fully seam welded
Not sure on the theory but car seems much more progressive and controllable with the softer springs in
Looking forward to seeing u guys down here again Craig
Mick
Yes it was butchers day mainly went to take daughter up and get her some coaching Did get some new ways of thinking about cornering for myself
Was handy to try new spring set as well only disappointing thing was they had 2 chicanes in back straight to try and keep us under !50 km lol and had us going through the bus stop as well like the bikes that was bit of fun
Do u reckon id get people wanting the navigators seat Thought I just who was silly enough to jump in there All lyle used to tell me in rally days was hold it don't back off don't think I ever heard him call a corner
Thanks for the pics
Mick
  • 2 weeks later...
Well mainlanders...Micks got his Mojo back!! 4th out of 33 cars at a damp Highcleare hillclimb today, the big fella was on fire!!! It's always had good traction off the line, but with the new lighter spring's it's dynamite!
Except when he was on the bridge...
