AK Posted October 24, 2016 Posted October 24, 2016 Hi Guys I have finished with my Rotisserie so it is up for sale I have only had it 12 months and its been through one build, it did the job easy and i will be selling it with the brackets and fittings I used to attache it to bumper bar bolting locations. It is located in eastern Vic about 40min from the CBD Great buy for some one ready to go intoor or prepairing for a full resto at . Manufacturers blurb below and some pics. When mounted I could hop inside the car while the body was mounted to the Rotisserie and you could actually spin the car quiet fast when standing on the side of unit as the balance piont was quiet good and the strength of the unit was great to. First in - best spun. $750.00 AK Tomahawk USA Designed Moto Max Truck Boat Vehicle Car Rotisserie Repair Restoration 4500LB/ 2040KG TWIN 8 TON RAMS, 178CM - 680CM MAX LENGTH $2499.00 RRP Second Hand Price $750.00 Description When you are lifting a heavy car, you want to be sure you can trust your equipment. You want something built tough, reliable, and dependable. That's why the MotoMax 4500LB Car Rotisserie is the ideal choice. Constructed from LifeTime Quality 3.00mm Gauge Steel, the MotoMax 4500LB is the perfect choice for the Commercial BodyShop or the Home Restorator. Featuring Twin 8T Hydraulic Rams, the MotoMax 4500LB offers 360 Degree Rotation with Twin Spring Loaded Positioning Pins allowing for Easy Access to Cut, Sand and Weld you Car or Boat. Built tough, the MotoMax 4500LB comes with a 3 piece telescopic arm that extends from 178cm - 680cm. Height adjustment can be made using the Twin 8T Rams, or for Smaller adjustments the Twin Handles can be used to set the centre of gravity. Fitted with 4 x 8" Injected Moulded Wheels and 2 x Smaller 3" Castors , the MotoMax 4500LB offers smooth manoeuvrability once loaded. Be quick. At a fraction of the RRP, you can't pass up this fantastic offer. Specifications Features · Tomahawk USA 4500LB/ 2040KG Car Rotisserie · USA Design · Twin 8T Hydraulic Rams · 680CM Max Adjustable Length · Twin Height Adjustment Handles · Twin Lock Pins · 4 x 8" Injected Moulded Wheels · 2 x 3 " Castors · 3.0mm Gauge Lifetime Quality Steel · Tomahawk USA Nothing Comes Close PRODUCT · Capacity: · 4500LB · Hydraulic Rams: · 2 · Ramming Capacity: · 8 Ton each · Adjustable Length: · 178cm - 680cm · Adjustable Width: · 39cm- 105cm · Adjustable Height: · 30cm - 119cm · Twin Spring Loaded Pins: · Yes · Twin Height Adjusting Handles: · Yes · Steel Gauge: · 3.0mm · Large Wheels: · 4 x 8" Injected Moulded · Small Wheels: · 2 x 3" Castors Dimensions & Weight · Packing Size: · 155*75*40cm · GW/ Nett Weight: · 215/ 190Kg Quote
Rickers Posted October 24, 2016 Posted October 24, 2016 (edited) Edit: Sent you a PM (I'd love to buy this depending on pickup location). Edited October 24, 2016 by Rickers Quote
AK Posted October 25, 2016 Author Posted October 25, 2016 Hi Guys - it sold today - thanks for your interest Cheers AK Quote
Rickers Posted October 27, 2016 Posted October 27, 2016 I still can't believe I got it all to fit in my fiesta, cheers for having it ready for me. -Rick CBR Jeff 1 Quote
jeff43 Posted October 27, 2016 Posted October 27, 2016 Excellent pickup Rick. So we will now expect a build thread with lots of pics. Good Luck Cheers Jeff (J2) CBR Jeff 1 Quote
Annie Posted April 11, 2020 Posted April 11, 2020 Hi is this still available and where abouts are you located. Thanx. Quote
Andrew_L26 Posted April 13, 2020 Posted April 13, 2020 On 4/11/2020 at 4:01 PM, Annie said: Hi is this still available and where abouts are you located. Thanx. Yeah, considering this post is 4 years old and there are multiple posts saying it's been sold. I reckon you'll be right to pick it up this weekend xD andyk_79, gilltech and gav240z 3 Quote
