C.A.R. Posted September 12, 2015 Posted September 12, 2015 (edited) SOLD! Hybrid 260Z / 71C gearbox for early 240Z. This 71C based gearbox has 260Z close ratio gears fitted: 1st: 2.906 2nd 1.902 3rd 1.308 4th 1.000 5th 0.865 * New brass syncro rings * All new bearings & gaskets. * All gears inspected for wear & damage - replaced where necessary. * It also has a short shift kit fitted that reduces the throw by 30% Includes modified shifter & gearbox cross-member. No throw out bearing carrier or clutch fork, but I can include these items if required for extra cost. Water-jet blasted housing available at extra cost. This gearbox will only suite a 240Z that has the vertical mounting holes in the tunnel - if it's a later '72 / '73 car this will place the shifter too far back in the tunnel. I built this hybrid box for my early 240Z, so that I could have a Close Ratio gearbox & still get the shifter to come up through the correct spot in the tunnel. It's done less then 2000kms & the oil still looks new. Only selling due to upgrading... Price: sold Located in Victoria Freight can be organized at buyers expense. Cheers Edited September 19, 2015 by Lurch ™ Quote
dat2kman Posted September 12, 2015 Posted September 12, 2015 Locky, is the back end ex RB20DET length, which will have the above as same overall length as the regular stocko B type boxes? Or, Is it the longer, by 50mm, VL Commo/Sylva back end, which will only require tailsjaft to be shortened? Quote
C.A.R. Posted September 12, 2015 Author Posted September 12, 2015 Is it the longer, by 50mm, VL Commo/Sylva back end, which will only require tailsjaft to be shortened? Correct. The buyer will have to shorten their tail-shaft by 50mm. Quote
lightmaster240z Posted September 13, 2015 Posted September 13, 2015 He going to a auto GongZ and George 2 Quote
Administrators gav240z Posted September 19, 2015 Administrators Posted September 19, 2015 Somewhat sad and happy, sad because I wanted it, happy because now I don't have to find the funds haha. Quote
Mr Camouflage Posted September 19, 2015 Posted September 19, 2015 Upgrade to what? That's what I'd like to know. Quote
