Mr260z Posted July 3, 2014 Share Posted July 3, 2014 I just brought some 16 x 7 superlites Is it normal to have to fit longer wheel studs? I have the tapered Allen key type wheel nuts and am only getting about 10mm thread which to me doesn't seem enough. Quote Link to comment Share on other sites More sharing options...
dat2kman Posted July 3, 2014 Share Posted July 3, 2014 Have a look through the NICE studs bolts and nuts catalogue Www.niceproducts.com.au They do a 44 ( or 46 mm?) mm long, and a 75 mm long, with correct shoulder and knurl for us. Easy to dock the long ones off f need be. Quote Link to comment Share on other sites More sharing options...
dat240z Posted June 19, 2017 Share Posted June 19, 2017 Hi guys, just after a little advice. I run the stock wheel studs, however since purchasing some Wats and requiring a 4mm spacer to clear the willwoods, I feel I need to get some longer studs to compensate for the spacers. The nuts are only grabbing the end of the studs. From my understanding the stock length is 32mm, does anyone know of say a 37ishmm stud length? Any help and or recommendations would be greatly appreciated. I looked through the NICE.com catalogue, but am a tad confused- not hard to do. Basically, I want the stock front and back studs however 4mm longer if that makes sense. Cheers Quote Link to comment Share on other sites More sharing options...
dat240z Posted June 19, 2017 Share Posted June 19, 2017 Also, are they press or screw in style.............. apologies for stupid questions! Quote Link to comment Share on other sites More sharing options...
dat2kman Posted June 19, 2017 Share Posted June 19, 2017 Press in. Need to make sure the knurl diam is same as regular. There is a 44 mm long? stud avail, from Nissan, this was for the 4wd Patrols. Yes standard ones are a bit short. Watch your lagalities/insurance with slip on spacers. Where possible, mechanically ( counter bored machine screw) affix the spacer to either your hub, or, to backside of rim. That way it does not become a flying saucer if wheel comes off. Quote Link to comment Share on other sites More sharing options...
dat2kman Posted June 19, 2017 Share Posted June 19, 2017 I dont have a NICE catalogue handy, post up a link or pic of the page/s that have the 1.25x12 studs. It should ay " suit Nissan" etc, there'll be a couple, plus the75mm long studs. Quote Link to comment Share on other sites More sharing options...
dat240z Posted June 19, 2017 Share Posted June 19, 2017 Thanks heaps Dat2kman. Yeah true re the fixing of the spacer - i think onto the hub would be the best as its only a 4mm one and isnt hugely differing the stock stance. Ideally I wouldn't even run them but its slightly rubbing onto the raised willwood lettering. Do you think 44mm would be too long? I have some genuine watanabe nuts which seem quite shallow. Ive found the Dorman brand from the states which look good and can be bought in a 39mm length which would be perfect. Quote Link to comment Share on other sites More sharing options...
dat240z Posted June 19, 2017 Share Posted June 19, 2017 Also, can you please confirm these are the correct "STOCK" dimensions: Knurl diam - 13.00mm Shoulder length - 10.00mm Thread - M12-1.25 Length (front) - 32mm (rear) - 37mm. Im thinking of leaving the rears as Ive done the disc conversion and already have the extra 4mm to compensate for the spacer. Or is it best to have a universal set? Quote Link to comment Share on other sites More sharing options...
dat2kman Posted June 19, 2017 Share Posted June 19, 2017 Sounds familuar! Easier to grab two x four-packs of NICE froma Bursons/Repco! Check the Nice pdf catledog though. If the nuts are Acorn capped type, you'll need to make sure that not only the 37mm have enough threads engaged, ( recommended is 9 x rotations of the nut, before snugging up) but, at 44mm the stud may bottom out in the closed nut. Re fixing spacers, if a neat slip fit over the four studs, you can get away with just one only countersunk machine screw M5 or M6 drilled/tapped into the hub. Quote Link to comment Share on other sites More sharing options...
dat240z Posted June 19, 2017 Share Posted June 19, 2017 Copy - thanks very much mate. Ill report my progress/results over the next few days. Quote Link to comment Share on other sites More sharing options...
KatoKid Posted June 26, 2017 Share Posted June 26, 2017 How did you go with this....I'm in the same place? Quote Link to comment Share on other sites More sharing options...
Agno Posted June 26, 2017 Share Posted June 26, 2017 I'll have a look when I get home. I have the 75mm stud part number written down somewhere and you should be able to cut them down easily enough. Quote Link to comment Share on other sites More sharing options...
Cozza Posted June 26, 2017 Share Posted June 26, 2017 Stewart Wilkins has them on his website. http://www.swmotorsport.com.au/product_info.php?cPath=17&products_id=1122 Quote Link to comment Share on other sites More sharing options...
dat2kman Posted June 26, 2017 Share Posted June 26, 2017 Stewart Wilkins has them on his website. http://www.swmotorsport.com.au/product_info.php?cPath=17&products_id=1122 NICE, same thing, around $5-6 each,,,,, Quote Link to comment Share on other sites More sharing options...
Agno Posted June 26, 2017 Share Posted June 26, 2017 NS4570 is the generic length (73mm) studs from Nice and they sell direct: https://niceproducts.com.au/product/ns4570-long-stud-nut/ Quote Link to comment Share on other sites More sharing options...
KatoKid Posted July 3, 2017 Share Posted July 3, 2017 I've just ordered from Nice as I need studs 8mm longer front and rear to get sufficient thread engagement. Standard studs are: Knurl diam - 12.8 mm Thread - M12-1.25 Length (front) - 32mm and shoulder 10mm (rear) - 39mm and shoulder 14mm It hard to find exactly what I need in M12-1.25 so as I'm changing both front and rear you get more options if you go to the more common M12-1.5 For the rear: https://niceproducts.com.au/product/ns350a-stud-nut/ Front: https://niceproducts.com.au/product/ns354-stud-nut/ I needed nuts so I've ordered studs and nuts but you can order studs separately. David Quote Link to comment Share on other sites More sharing options...
KatoKid Posted July 6, 2017 Share Posted July 6, 2017 Perfect, just need to press them in. Quote Link to comment Share on other sites More sharing options...
peter t Posted August 19, 2018 Share Posted August 19, 2018 (edited) On 7/6/2017 at 5:15 PM, KatoKid said: Perfect, just need to press them in. I am going NS 370 all round should do the trick. Just have to get new lug nuts to suit thread. Regreased bearings as I am going. 12x1.50 / 12.9mmK / 43.8mm L/ 13.2mm S. Edited August 19, 2018 by peter t Quote Link to comment Share on other sites More sharing options...
