Hi everyone. I'm chasing the 6 thick bridge washers used to mount the intake and exhaust manifolds. Does anyone have any spares?
Alex
If handy with Oxy or a mg/tig, probably easier and quicker to make some up, to the stepped thickness you need.
The raised bit only needs to be 1/3rd of a circle.
I used to oxy mine up, and surface grind to height required.
I've got a spare set if you want them.
These were made up from washers by an exhaust shop when I had some headers fitted.
Strangely 1 is flat. The other 5 have a step on them.
I'm in Gisborne if you want to pick them up (or Docklands during the week).
Or I could mail them free if you donate to the site...
Gary
Thanks for the hits fellas. A friend of mine is going to spin some up out of stainless and is asking if anyone else might be interested?
I used the big thick exhaust washers off a stock RB30 exhaust manifold i had attached to a box (you know what im talking about Agno)
I ground the step into them where needed with a bench grinder.
