- Today
- Yesterday
HS30-00171
The Ratson
Yep... did cross my mind it could feel like asking how long. But..for whatever plans someone had, if they really regretted not doing something, or nearly didn't do something and are so glad they did... they would be very aware. They mights just not end up being relevant for my plans. Which are still evolving.But they essentially involve: L26 engine Tripple Webbers 5 speed manual box (don't know what options exist) Subaru A/C system Possibly a body kit (flares, side skirts, air dam, haven't seen a spoiler I like yet.) Possible after market front suspension to eliminate rumour of bump steer Thanks very much for the link, info on the fuse box. They sound good. I'm planning to assemble the entire electrical system by itself, as much as possible, on the garage floor, all switches, gauges, lights, electrical components, and verify it works. I definitely have a few rat chewed wires. Insulation must taste nice. - Last week
The Ratson
- 1 reply
- 260z
- efi conversion
(and 1 more)
Tagged with:
https://www.facebook.com/marketplace/item/895800226103235/?ref=search&referral_code=null&referral_story_type=post Might be worth finding out the chassis number for the database -
https://bringatrailer.com/listing/1970-datsun-240z-147/ HS30 99 The seller is Jon Newlyn who also owns MBP72J which was one of the first (if not the first) car in the UK, the VIN slips my mind at the moment. -
