  1. Past hour
  2. I'll have a look tomorrow (aren't at the location of my car until then). I know I have two auto shifters, and I going to convert to a manual. But you know what they look like.. A nut and bolt store might be the go. Mine could be quite rusty..
  3. Yesterday
  4. Surely someone who has done a manual conversion has these!? If anyone has these screws, please message me! Sth East Melbourne location.
  5. The painted suspension going back in with new bushes:
  6. Last week
  7. Finally got some paint on 905 red is very red? Found some braided hose (slightly lighter braiding than original but better than straight rubber) and used 2 strands of copper wire to shape. Looks ok but wire might be too soft? Printed a hinge for tool box needs a bit more work hinge too stiff
  8. Assembly could now begin. All the plated parts were organized, and any sub-assemblies were put together. The fuel and brake hard lines were installed in the chassis, followed by the brake booster, brake and clutch M/C's, and pedal box. The firewall mat was supplied by ZCarDepot to suit a RHD Z, but it needed much modifying to fit. Very disappointing and I don't recommended it.
  9. With Daniel wanting a lower Z, we needed to have the strut tubes shortened so we could maintain effective bump travel. I took some measurements, then sent the bare struts off to be shortened and the gland nut threads recut. Being that the struts are 55mm (with the long rear tube), the rear needed a spacer in the bottom with a spigot to engage the bottom of the Koni insert to pack it up and keep it central, so a pair were machined up out of aluminum. We then assembled the struts with new Lovells lowering springs and their rebuilt braking components so we can fit the struts to the 260Z and get it rolling on it's wheels.
  10. https://auctions.chicaneauctions.com.au/auction/august-2026-collector-performance-rare-car-auction-30/item/1973-datsun-240z-376/
  11. Nismo 10th anniversary steering wheel, mint condition, $1150.
  12. Earlier
  13. 45mm Steel Hub Dust Cap Zinc Plated - 2PC - Superior Trailer Parts 45mm outer, same as z front hub bearing caps..... massive price difference from original and ill be powder coating these black .... not sure if anyone has tried this before?
  14. Refer to the donk in the engine bar: and maybe the flares too haha
  15. I need the following items, does anybody have these or know where to buy without freight costing $100 for an envelope!
  16. https://www.carsales.com.au/cars/details/1969-datsun-1600-manual/OAG-AD-24642820/ or here https://autodynasty.com.au/buy/1969-nissan-bluebird-/Q2QGzaynhcol8AVATQrdqA Another ripper!
  17. Would be interesting to start a discussion thread mods you wish previous owners HADN'T made!
  18. Go to this youtube video: Go to approx. 1.0 minutes. This is LHD VIN#16 which was one of the first cars sold to the general public in the USA. The car was originally gold and was repainted white in the early 1970's. The stickers/decals were applied to the time of the repaint. Its 1970's cool.
  19. I love originality, but for me... Upgraded Brakes Fuel injection and modern ECU Air Con (for hot summer days in Australia) Upgraded wiper and heater / fan motor. Makes the car infinitely more usable all year around.
  20. Another local option is Coilovers by Supafatto. You can find him on Facebook or below. https://www.pitloon.com/businesses/supafatto
  21. $3k-$4k buy the time it's all done. We are in the Latrobe Valley.
  22. What’s the cost to do this as I’ll probably end up going this way too? Where are you located?
  23. I'm currently working on Daniels suspension for his restoration. The struts are away getting their tubes shortened so we can obtain enough bump travel. Then to get the ride height lower still with the Lovells lowering springs, I'm going to drop the perches on the tubes until I get the ride height I'm after. I ended up using Koni Yellow Sport damper inserts from the front of a Z31 for all for corners, with a special Koni gland nut to suit the 55mm strut tubes. In the future if Daniel wants firmer springs or the ability to easily adjust the ride height, he can fit height adjustable platforms.
  24. Always been a huge fan of pin striping on vehicles and would love to see if any members have gone down the route of putting stripes on their z's and would love to see some pictures..... The more 70's retro the stripes, the better. GO!
  25. what did you end up going with and any pics showing ride height?
  26. (Ok, not sure why it won’t let me add my text..) Possibly how long is a piece of string, but can I ask here what would be a typical price for that process, assuming the car is “roll in” ready? Though it will be years before we are in that situation. Cheers….
  27. I went with some products from Car Builders : 1) Insul-Layer - applied to inside of doors and rear quarter panels 2) Mass Noise Liner - used in place of the old sisal under carpet areas and on the firewall. From their web site : "Sound deadener is generally a misunderstood material. Normally the first stage of treating noise is referred to as ‘sound deadener’. This stage only really treats vibration in panels. It was often a bitumen-based product but more commonly consists of a butyl rubber with an aluminium top layer. Cheaper sound dampening sheets consist of a lower grade butyl, which is not as durable or resistant as those used by leading brands. Butyl sheets by themselves however, will not result in dampening droning or external noise that you may be more interested in treating. This will be treated more successfully with mass loaded vinyls. If you are aware of the type of sounds that are annoying, you will be able to treat them more successfully with targeted products."
  28. In our shop, from bare metal we Epoxy, then prime, then mask off the rails, stone chip the flat panels, then apply body colour over everything. IMHO This is the most professional way to go about the underside of a Z:
