- Past hour
- Today
Update: Master cylinder removed. Those flange nuts were stuck tight as. My inexperience led me to go too far with the 10mm flange spanner, I was going slow but I tried too many times and stripped them, I was annoyed at myself. I got PB Blaster and then some heat to them, then used a vice grip and eventually got them undone. But I feel like I wrecked the nuts unfortunately. Seems to me my options are (but definitely happy to be corrected): A) Struggle and get the other end (proportioning valve end) off and take it to my mechanic to make equivalent lines B) File the nuts flat. But feels unsatisfactory, will be hard to get them on-off in the future, looks fugly. C) Buy the double flaring tool and steel line (or cunifer?) materials, try and do it myself, I reviewed a load of youtube vids on double flaring, seems a bit of skills is needed - Earlier
Hoody joined the community
ROTL joined the community
My Blue 260Z 2Seater
PHATSUN replied to PHATSUN's topic in General Discussions
wheelers Hill -
AndBir replied to PHATSUN's topic in General Discussions
Which SE Melb suburb? -
I have sent you a message? What SE suburb are you in?
Thank you but Moe too far for me. Just need someone to come to my garage in Melb and do bits n pieces in their own time for some cash really.....any hobbyists out there can surely provide some help. Ya'd think lol -
gav240z replied to PHATSUN's topic in General Discussions
Give them a little while, they posted a while ago, but the posts remained in the approval bin for a week or so. I didn't see them immediately.
