Refitting the panels prior to painting.
Fitted doors and have a </>5mm gap to rear quarters and to sill  and swage lines line up (should I fit rubbers and door hardware?)
Do I just work my way round the car and try to achieve an even gap?? I guess all panels have to be bolted up
What kind of gap should there be between scuttle panel and wings also between inspection flaps and wings
Also how to correct a slight taper to front of bonnet/wing one side only
Advice /pictures welcomed
Nick
  • 2 weeks later...
Thanks
Don't need to fit locks/seals just set gap door/rear 1/4 and work from there?
Set the gaps first.
You may need to find a suitable door seal if one brand is too 'fat'.
