- Past hour
START DIGGIN! I NEED IT hahah
- Today
I know I have one from an Aus delivered 260z I just need to find it
yeah i always wondered about people buying those in the US as I am assuming the indicator and headlight switch is the other way round anyhow....
Just be wary of any ones you find on eBay as it appears the USA ones are quite different to those on the Aus delivered cars and most of those shown say "Untested" so will have faults.
RichyRich replied to gav240z's topic in Cars For Sale
1974 260Z tarmac rally car RS30-001049 $38k https://www.my105.com/search/details/1974-datsun-260z-rally-car/15d332ff-519c-436f-b61e-a767b37040cf?source=SEARCH_RESULT 1971 240z Rolling shell build no 1561, $11k, sold (nice dash!!) https://www.my105.com/search/details/1971-datsun-240z-s30-shell/97cffddb-cb34-4fd1-8c8e-104eb276994f?source=SEARCH_RESULT 1973 240z $59.9k https://www.facebook.com/marketplace/item/802898422754548/?ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp%3A545b2a98-9789-4092-a11e-38d4a71aed48 -
PHATSUN changed their profile photo
Joe you kept my motivation going, thanks. Update: I set the "Fun" level to 10. I bought a flaring tool. From EFI Solutions I bought: steel 3/16 brake line and stainless brake tube nuts (M10x1.0mm) so an ape like me can't strip them again. I've had a crack at double flares and finally got them tight enough to sit nicely against the nuts - I guess until I pressurise them I won't know if I did a good or a bad job. It's not like I'd have to undo the whole thing if they were bad....oh... The brake juice had stripped all the paint off my rails so whilst I had parts removed and some access...first attempt at rust converter last night, it's a mess. Then some primer later today straight over it. What could POSSIBLY go wrong? (/sarcasm) Anyone feel free to correct me if I am off course. Next: primer, then rattle can of VGPaint 306, then tape it all up ready for more leaks, then bend the brake lines into shape, test fit, redo it x10, then bleed brakes. -
Hoody joined the community
ROTL joined the community
My Blue 260Z 2Seater
Sounds like it wasnt put back together too well. Was it honed or sleeved? Was a new rubber seal kit installed? It will be the rear rubber seal inside the master around the pushrod that is leaking. Master needs to come back off to fix it. Hope this helps. Please keep us updated as to your progress. <Edit> The seal/s in question are not around the pushrod; I wasnt thinking straight when I typed the reply. The seal around the pushrod at the rear is a dust boot, the seals that would be leaking are inside the bore of the master cylinder.
