- Past hour
- Today
- Yesterday
My Blue 260Z 2Seater
lpkadlec joined the community
PIN STRIPING
DBongard joined the community
BenjiT joined the community
- If you have to rebuild the L26, look at rebuilding an L28 instead. Depending on your budget for the motor, you can get a decent build out of Pearl Automotive Engineering (VIC). - Buy brand new Triple Webers from Weber Performance (VIC), and go straight for 45s. Even if you put the L26 in, and an L28 is an option later on, atleast you will have 45s already.
