- Past hour
Hoody joined the community
ROTL joined the community
My Blue 260Z 2Seater
PHATSUN replied to PHATSUN's topic in General Discussions
wheelers Hill -
AndBir replied to PHATSUN's topic in General Discussions
Which SE Melb suburb? -
I have sent you a message? What SE suburb are you in?
Thank you but Moe too far for me. Just need someone to come to my garage in Melb and do bits n pieces in their own time for some cash really.....any hobbyists out there can surely provide some help. Ya'd think lol -
gav240z replied to PHATSUN's topic in General Discussions
Give them a little while, they posted a while ago, but the posts remained in the approval bin for a week or so. I didn't see them immediately. -
C.A.R. replied to PHATSUN's topic in General Discussions
