Wink Security joined the community
Which Mig Welder To Buy?
Lincoln 180C - it's what we have in our shop. They are transformer, full manual manchines. Very easy to use, set up and super reliable. They are more expensive though at over $1k
Dibbozzzz joined the community
https://metaljointpro.com/what-amp-mig-for-car-repairs/ This seems a very helpful article…. Reinforces some of the points made in the preceding pages. Heading towards the Cigweld XF186. Think it has a suitable current range, and allows full manual control for fine tuning, not just stuck with quick pre set voltage/wire speed based on wire diameter and material thickness. $750 as a base machine, $800 with extras such as helmet, gloves. But always open to advice.
Started learning how to mig weld, while sorting out blasting, spray guns, compressors and priming. These are the first few attempts, on a 3mm plate. 20v, 5m/min, and a flow rate of 16 (l/min?). Forget the wire size. Had a bit of a tendency to hold the tip too high, and move a bit too fast. Found listening to the arc almost as helpful as watching. But not too bad I think, very happy with these though 1.2mm sheets will be a lot harder. So will see if we can do that sufficiently well. And welding on a practice piece that's going in the scrap bin is different to welding on your car that if you stuff up there are consequences.
I doubt you'll find a NOS RH door mirror here. I haven't seen one in decades. FWIW I fit the LH mirror to the RH door on Zeds here and it works perfectly well. However if you fit a LH mirror to a LH door and try to use it fro the RH seat, you can't get enough articulation out of the pivot to see down the side of the car. I suspect if you fitted a RH mirror to your RH door, you would have a similar vision issue from the LH seat...
Engineers certificate question
gav240z started following Hot girls are just a click away and Engineers certificate question
Not sure what this group can do in terms of VF Commodore advice? We are focused on Nissan S30Z series.
Hey guys so Vf commodore its currently regoed as v6 I have found somebody thats willing to give me a roadworthy with v8 engine numbers that I bought a v8 engine to do the swap now would vic roads catch on to it an make me bring the car or would the roadworthy certificate be ok an just pay everything online an move on or what should I do has anybody done that
Bushbasher joined the community
grahama joined the community
GrandpaZ joined the community
zuperair joined the community
Vdgmich joined the community
Swebbs joined the community
Wobbles joined the community
The Ratsun
door alignment
HS30-00211
