NickF Posted September 23 Posted September 23 In the process of aligning drivers door can't seem to get the bottom 1/3 of door aligned Door sits out by about 8mm from sill and tapers to good fit above swage line Can't figure out how to pull in bottom of door Any advice? Thanks Nick Quote
C.A.R. Posted September 24 Posted September 24 Are the doors original or reproductions? Slot the door mounting holes in the bottom hinge to move the door in. Quote
NickF Posted September 26 Author Posted September 26 Thank you Great advice as usual Worked a treat Door lines up really well had to grind a little off hinge Excellent OEM door Nick C.A.R. 1 Quote
