Author Topic: What Gearboxs Fit  (Read 6966 times)
Offline Six_Shooter
  • Registered User
  • Canuckian
Re: What Gearboxs Fit
« Reply #15 on: October 31, 2011, 02:26:16 PM »
Which "260 box" is cited above as needing the shifter modification?
I fitted a 280ZX box, same or similar to 260/280Z box, and used the 240 shifter. It cleared the floor without issue.
Offline Lurch
  • Locky
  • Global Moderator
  • Registered User
  • Oracle of BS.
« Reply #16 on: October 31, 2011, 04:07:58 PM »
A 260Z box 'can' clear the floor OK depending on the shifter, but it won't clear the 240Z centre console.
If your's did, are you 100% sure it was a 280ZX gearbox?
Offline Six_Shooter
  • Registered User
  • Canuckian
« Reply #17 on: October 31, 2011, 09:20:56 PM »
Yes, 110%. I pulled it from the donor car myself. ;)
Offline Mr Camouflage
  • must stop buying z's with sunroofs
  • Registered User
  • www.wazcars.com
    • www.wazcars.com
« Reply #18 on: November 01, 2011, 01:01:13 AM »
Hey Lurch, what about the 71C from a Z31, with a bell housing change. Will that fit (with or without shifter mods)?
www.nostalgictrio.com
'65 Silvia CSP311 #340 & #342
'70 & 72 240Z
'73 240K Hardtop & 77 Sedan
'84 300ZX <-- For Sale
'88 Skyline GTS-X (Daily)
'01 Prius (Soon-to-be Daily)
Sold:
Z31 Turbo, Super 6, 240Z, 77 Celica, 808 coupe, TX3 4WD
Offline Z
  • Donating Member
  • Registered User
« Reply #19 on: November 01, 2011, 05:20:32 AM »
I'll lob something in here to make it even more confusing Mwahahahaaa!
Now I'm no expert in this stuff but I've just had a 71C recoed and the 260 bell modified, god knows when it will end up in the car though.
While I was speaking to Stuart from SWM about the gearbox mount modification for this upgrade, he said that the year of your 240 will also affect where the stick ends up. Apparently the earlier cars (being 71) tunnel hole is further back than the later cars (72, 73), so yet another consideration.
I guess if you want to do a 71B/C change it obviously can be done, you will have a few mods to consider that are particular to your car/gearbox/console combo.
Offline Lurch
  • Locky
  • Global Moderator
  • Registered User
  • Oracle of BS.
« Reply #20 on: November 01, 2011, 06:28:52 AM »
OK, this is not a walkthrough for 71C gearbox conversions, guys.
« Last Edit: November 06, 2011, 01:19:00 PM by Lurch »
Offline Z
  • Donating Member
  • Registered User
« Reply #21 on: November 01, 2011, 06:47:18 AM »
No it's not a thread on 71C conversions, it's a thread on "What Gearboxes Fit" and Camouflage simply asked if a 71C would fit...
Do whatever you like, I'm pointing out that different cars have different locations of their gearbox lever tunnel thingo hole lol, quoted by someone with more knowledge than most... Seems pretty on topic to me.
Offline tbscobraZ
  • Registered User
« Reply #22 on: November 01, 2011, 09:51:03 AM »
Has anyone ever but an RB26 (auto) box behind and L-series? Not the 4wd one obviously the rwd one out of a R34.
  • Registered User
  • www.wazcars.com
    • www.wazcars.com
« Reply #23 on: November 01, 2011, 10:04:41 PM »
Was just asking about the Z31 since you mentioned  "the 300ZX (Z32) will fit but require bellhousing modifications.", and I have a manual Z31 i'll probably be wrecking.
'70 & 72 240Z
Sold:
Offline dat2kman
  • Registered User
  • comin' down the mountain!
« Reply #24 on: November 01, 2011, 11:13:03 PM »
I have a large selection of gearsticks, approx 15, from various 71 boxes, A,B&C, they all have odd bends forwards, backwards, big bits of flats at pivot, and straight up.
The earlier 240 with a71a a longer box, the stick is straight, the later 71b the box shifter location was closer to engine, and to get stick i. Good psition, factory bented it back a bit. Some have S bends etc.
 All nothing a bit of trimming a hole and screwing a bit of rubber flap wont fix
The factory competition option 1 2 3 boxes all had straight sticks, and a wooden knob, with a small silver metal button imbedded.
I just race old datsuns:
