zzzzed
Everything posted by zzzzed
  1. Ok two years age passed and it’s getting a lot closer now. It is all painted and moves under its own power. there’s still a bit to go yet however. IMG_4404.MOV IMG_4404.MOV
  2. It only has taken this long because I build it in between customers cars. I have built 9 or 10 other cars in this time. the stance is because it has no springs because I wanted to clearance the wheels at Full drop because I am running 9” rims all corners
  3. Talk about post revival 8 years later I am still building this car but it is getting closer to completion.
  4. zzzzed
    Wanted - 240Z
    Pm coming
  5. Ahh ok. I think I need to get it on th dyno and let some one who knows what they are doing have a go.
  6. I was going to ask for a beaver but I think after looking at those pics I could actually do a better job making them my self
  7. I havnt touched the idle speed. I might up the timing a couple of degree and see if I can add a bit of fuel to the mix to try stop the pinging
  8. Hmm I think the total advance of the dizzy is around 22 degree
  9. That wouldn't make it preignite though would it. I thought it might be a carbon build up and now it is burning hotter the carbon is making it preignite
  10. I have recently swapped my standard points distributor for a Mallory electronic distributor First issue was I had to reduce the timing from 10 degree down to 5 degree to stop detonation Second issue is that I am now getting preignition after longer drives. Could the stronger spark be making the fuel mixture lean? I am running British Su carbs from an Austin Healy on a standard l28.
  11. You take some pretty good photos. I hope you don't mind I have stolen the photos you took of my car. They are my new favourites. ?
  12. No mate all you need is the passion.
  13. Just my opinion but a rotor in a zed is as wrong as it gets. Sure it would go well and be a barrel of laughs. But just no. It just doesn't sound right. Sorry gav. ?
  14. Scroll down for the goodness http://www.speedhunters.com/2015/10/recording-the-sounds-of-need-for-speed/
  15. I havent had any scrubbing yet mate It is back to round top sucarbs right now but when it had triples I put the smallest choke size in them I could for the stock l28.
  16. Hey mate the wheels are 15x8 zero offset Tyers are 205 60 15 I did the naughty chop chop on the standard spring until I replace them with coil over when I give it a full rebuild. I cut 1 full coil out of each spring.
  17. Some low happened this weekend. Check out the before and after shot
  18. I am not to sure about that front bar. I would have to see it painted
  19. Dam to slow to reply. I was going to take those Pistons. ?
  20. $3149
  21. I see my old gear box x member ? Have the seat rails been taken?
  22. A couple of reasons. That much power will only get me in to trouble on the road and I could not be bothered having it engineered. A good L series will produce all the power you could possibly need/use for the road and I think a trippled L is just slightly old school cooler.
