Something has come up so I have to let go of my track car.
Here is the write up.
Engine: RB25
Pistons:forged JE 10.5 comp ratio
Rods:spool/ARP 2000 rod bolts
Injection: 2000CC Bosch injectors/E85 with Turbosmart FPR1200 regulator
Twin wilbora pumps with carter black lift pump/2ltr surge tank/custom swirl pot on bottom of stock tank
Head:Valves recut 3 ways
Heavier valve springs
Cams 256/256 8.5 lift Pon cams
Oil system: 7.5 Ltr custom baffled sump. N1 oil pump with billet gears/crank collar spool.
3 qrt accusump with non return valve at oil filter. Oil cooler with remote filter. Rear spool head drain. Savage pump on oil catch can.
Turbo GTX35R ball bearing/.86 Rear housing.
ECU: Haltech platinum with Haltech Dash/ have Topstage Composites dash to be installed in carbon fiber to go with the car. Microtech X6 ignighter pack with Bosch coil packs.
Trans:custom clutch single plate 3200 pound direct clutch services
Stock RB25 transmission.
Diff: custom Long nose LSD centre from S13 Silvia. Custom mounted diff.
Wolf Creek Racing half shafts
Suspension: Arizona zed car race adjustable struts.
WRX STI power steering rack 2.5 turns lock to lock.
Adjustable A arms
Adjustable caster rods
Teckno toy rear adjustable Rear lower control arms.
Brakes: front 6 piston willwood calipers/315mm rotors
Rear 4 piston willwood rotors/295 mm
Willwood brake bias controller
Master cylinder 15/16" 280zx
Booster R33 skyline duel diaphragmed type.
Roll Cage: 6 point
Seat: Race Tech / 5 point harness
Aero: front splitter Topstage V2
Rear splitter and spoiler Topstage in carbon Fiber. Flares dry carbon
$30,000
May swap for road regoed 2 seater of the same value
