d3c0y
Everything posted by d3c0y
  1. ... and if you use one of those RB30s that came from the factory with a carby then it is legal to run triples on it too.
  2. Pretty sure it's internally oiled, and use it has a number stamped on the end of it. I got the specs on email when i bought the cam so no mind trickery there. I was going to try and come up this weekend, i've got your mobile so i can call you first before i come.
  3. How much do you think they would be shipped to qld for the hurricanes?
  4. Next question is what happens as the pin height gets closer to the top of the piston? Is there a pin height that is too low? Because you could use VH45 rods and get an even better rod to stroke ratio with 147.32mm rods
  5. d3c0y
    Tight small ends
    Yeah i tried to get a pin out of one of them and couldn't using a quite significant amount of force. You are right though the pistons should be binned and the crank and rods checked for damage. I was putting the question out there out of interest just to learn a bit more about it more than anything, not going against what you said. Thanks for clearing up that bit about the balancer - it had me guessing Why bore it out? More HP
  6. d3c0y
    Tight small ends
    Yeah i ended up picking up an F54 which i ultimately wanted for $100, so i am going to build my race motor out of that. I was just thinking of putting this together for the interim to replace my L24 which is using shite loads of oil. I was more wondering what common causes of the pins being tight are - like oil starvation or as you said bent pins. Bent pins is pretty radical though. I reckon that siezing the little end bearing would be enough to scuff the skirts. I guess i bent a crank once and the car still drove. It's already got .040" pistons in it so thats bad news might need to hog it out to .120"! You would think if the pistons were twisting on the way up that the crank bearings would have noticeble damage, they didnt look too bad though. I couldnt find any evidence of welding on the crank snout either? The front keyway is bent quite badly though.
  7. This is coming from a Z32 owner that came from a 260Z 2+2 DONT DO IT! Z32s are all flogged out and very expensive to maintain. I totally agree with buy a good 240Z instead I've dumped about $30k into my Z32 and i have driven it for less than a year in 6 years of ownership.
  8. You need to do that because it doesnt run a stock base circle (?is that what it's called?) to get more lift out of it i think. Also you need to set the correct rocker angle to get the correct wipe patten on the arms. Because this is different for every motor I doubt that .263 will be correct for all valve set ups but at least will be a good starting point. The lash pads i can sell are .290 and .360 so you could grind them to whatever you require.
  9. That's awesome thanks - answered all my questions.
  10. d3c0y
    Tight small ends
    Hey Guys, I just pulled an L28 apart and some of the rods feel a little tight to move left to right on the pistons, it's probably on half of them. What does this symptom indicate? Bores still look good and the baring sheels dont show any major scrubbing. It looks like this engine was rebuilt pretty recently.
  11. When i say 9000rpm i dont mean for long periods. 8k-8.5k would be normal operation of longevity's sake. NZeder: From what i've read cast pistons are too weak for high rpm, or is that just factory cast pistons? And for $1100USD, its pretty much the same price as Peter MC's custom forged slugs. I just did another search and found that JE will do the pistons i want for around $900 - not too bad. My question hasnt really been answered though. Is there an noticable power difference going from 87mm to 89mm pistons? I would like to get out of buying aftermarket rods if i can and just prep a set of factory ones, i already have the 9mm arp bolts for them. It would be awesome to get 6 stock FJ rods and prep them. Probably be pretty hard work these days. I was going to put the money into pistons and head development instead. Peter: why not go the 89mm bore?
  12. Hey Jason As stated it's an Ameri-cam I don't have the cam with me at the moment so I can't tell you what the model number is but I can bring it with me on the weekend when I grab the head. I did google the model number and didn't come up with anything. The cam was ground on a datsun blank and has not been used. I don't have the spec sheet.
  13. Has anyone ever ordered pistons similar to this spec and how much did it cost? Is the displacement & rod to stroke ratio worth the effort over a .040" overbore with standard L28 rods? The engine will be running Mikuni 44s with 40mm chokes, high lift cam .580" kind of region, ported E88 with light weight bigger valves hoping for 8k - 9k rpm.
  14. Hey Guys, Up for sale is my ameri-cam L series cam shaft i bought in the states. This is not your average street cam and you will need a few mods to support it - i.e. it wont work with twin SU's and a stock head. Lift is .555" and has 300 intake, 316 exhaust duration. It is ground on a 111 lobe centre. It has been ground on fresh Datsun billett and has never been fitted to an engine. It requires .263" lash pads which i can part with for aditional cost. RPM Range: 4000-8500 RPM $350
  15. Fair enough then i'll conceed based on that lol I have a crane it works
  16. If you google the numbers on teh side of the dizzy you should come up with something - that's how i did mine.
  17. Do you care to elaborate on this?
  18. What's the difference between these and a series 1 hilux caliper?
  19. Or you could just buy the crane HI-6 that is better than the 6-AL, has built in trim pots for rev limit and you can pick one up for under $200AUD second hand...
  20. The flairs look like MSA ones to me www.thezstore.com/page/TZS/PROD/7BSA02/50-1565
  21. What sort of bumper is it? What does it look like?
  22. Kind of weird that no one has mentioned retuning for the fuel. A bit part of E85 is the oxygen content in the fuel and from what i've read you need to check your AFR to make sure its not running super lean. You would probably have to change your carb jetting / mixtures to be a lot richer for your car to run right.
  23. Link fixed got it back the front. My bad i didnt read the whole post properly in regard to teh master cylinder was going out and just tried to answer the guy's questions quickly
  24. 1) You need to do Step 5 2) No 3) Pretty sure the caliper bracket will fit both S1 & S2
  25. d3c0y
    L28 in Brisbane
    Yeah it aint what it used to be. Back when i first had zeds you could just go down to the wreckers and pull appart a C110 or a 280ZX most times. I remember getting L28 dizzy's and heads for $30 ea wish i hadnt given them all away! Oh and i managed to pick one up off ebay F54 short motor + garvice's N42 although im not sure how healthy that one will be.
