706 -
2
Everything posted by BenZed
Went to Wakefield a couple of weekends ago. The Zed was a bit of a handful, since I still haven't touched the suspension or brakes (had an epic spin into turn one). Also had a mystery fuel leak from the filler and the recently-rebuilt box kept popping out of third gear on decel... just my list of excuses for only doing 1:12 laps I'll head down again once the issues are sorted. Here's a pic from the local snappers at Wakefield.
Please refer to this thread for all further posts: http://www.viczcar.com/forum/index.php/topic,4074.0.html Thanks
These head castings have been sitting around at OS Giken for years. The first time I went to the factory 8 or 9 years ago they were stacked up in a corner. Don't know why they suddenly decided to use them.
Good question, but I'll decide once I get the new bits from OS. I do have a 240K GT sitting in the corner of the shed waiting to be turned into a Ken Mary replica (GC110 GT-R)
Here are the TC24-B1 heads being prepared. There are five for customers and one for a new OS Giken demo engine.
Yes, I already put my name on one. Unfortunately the rest are all presold to US customers
Yes, have them in stock, will clear just about any brakes and fit without spacers. Call 02 8798 1469 to order.
To give you an idea the RB30 crank from OS Giken retails for $7700. The pistons are quite reasonable at $1400, not sure about the rods.
This is a very exciting new product coming soon from OS Giken. The stroker kit for L-series 6-cylinders will offer 85mm stroke and 88mm bore for around 3103cc capacity. I have no pricing or other information yet, but I will post it up as soon as I know. In the meantime Kameari do offer a similar set-up, using a modified LD28 crank to get 85mm stroke, 138mm conrods and 89mm pistons (29mm pin height) for 3171cc capacity. The OS Giken crank will be a much more impressive item, most likely a full-counter-weight billet type, suited to much higher rpm. The conrods appear to be similar to the forged chrome-moly H-beam type in the OS Giken RB30 engine. I better stop writing now...
Sorry no pics available yet, but I imagine they're similar to the American ones on my car (see members projects)
Some more parts added to the original post. Note the cowl panel and bumpers
YouTube: A look at datsuns over 30 years
BenZed replied to JazzaDam's topic in Business Directory + Links
Got sent this video from Poland yesterday. Pretty cool http://www.youtube.com/watch?v=bIl_loa9MvY -
I'll be listing parts I have lying around in my warehouse on this thread.
might want to PM Lurch about that, I think he is fitting a set
I haven't personally tested them back to back so I can't really comment on this. OER claim they are better and the other comments here seem to confirm this.
I will get these made in about two months. We will have to use 70mm ID springs to suit.
OER claim to have improved fuel atomisation compared to Webers and offer a huge range of jets etc.
Sorry no boss kits yet. They will fit a Nardi boss, but as you mention a short one is preferable. As for the old school rims please see the post about this. PM me if there is a specific Rota rim you want. Cheers
I have only a few old wheels left in stock. Due to the exchange rate I am not bringing any more in for a while, so I can't take special orders right now. Grab these while you can: http://www.otomoto.com.au/photos.htm Scroll down the page for 15-inch and 14-inch.
New product I just got in, unlike most weld-on coilover sleeve kits on the market these come with springs AND helper springs AND spanners. Everything you see in the pic is one set, which is $299. Two pairs for $500. The 51mm sleeves to suit 240Zs (front or back) come with a choice of 4kg or 5kg springs (224lb or 280lb). I can also supply other rates if needed. The top spring locator has a small 8mm hole so it can be drilled out to suit your struts. Other than that you should just need a few washers to make everything sit right. PM me if you want a set.
Rota Grid These are 16x8 +10 offset, 4x114.3 PCD in the bronze colour pictured or metallic black or white for $279 a wheel. Wheel weight is 8.21kg. The hub size is slightly small on the front, but they will fit using a 3mm spacer. Alternatively you could machine the wheel or the hub slightly to make them fit perfectly. To save anyone asking, no they don't come in any other size, offset or colours. Rota RB As you may already have seen on the above post, I have Rota RB wheels to suit Zeds in stock. 15x7 +4 7.35kg $207ea 15x8 +4 7.77kg $229ea 16x7 +4 7.55kg $259ea 16x8 +4 7.52kg $289ea 17x7.5 +4 8.66kg $319ea 17x8.5 +4 9.27kg $329ea 17x8.5 +20 9.25kg $329ea (this size is 5x114.3) 17x9.0 -13 8.74kg $349ea 17x9.5 -19 8.74kg $359ea Note that the RBs are much lighter than equivalent 'Superlites'
Through one of my contacts in Japan I can now source O.E.R. products like the 6-throttle injection kit I'm using on my car. This kit is available with 45mm throttles or 50mm throttles. The kit includes the throttle bodies, manifold and linkages. Additional parts like injectors, fuel rail, air filters and throttle-position-sensor can be supplied at extra cost. The 45mm throttle-bodies are designed to take one injector per throttle (6 total on the L6 kit) while the 50mm throttles can take a second set on the underside if needed (for example if using methanol fuel). 45mm throttle body kit for L6 $2700 50mm throttle body kit for L6 $3700 For anyone interested in triple carburettors, I can also supply the chokeless O.E.R. Racing Carburettors, which are available in 45mm, 47mm and 50mm. An L6 manifold is available to suit these carburettors (right up to the 50mm type). The 50mm carburettors aren't cheap, but if you've ever priced a 50DC0E Weber you'll know these are actually good value. A big advantage of OER carbs over most side-draught carbs is that the accelerator pump and float level adjustments are on the top of the carby so they can be tuned easily. 45mm carburettor $690 47mm carburettor $755 50mm carburettor $1220 L6 OER manifold with linkages to suit up to 50mm carbs $749 Note that the 45 and 47mm carbs can be ordered with Weber jets or Solex Jets. Any questions please PM me. Cheers
I have a contact at Restored in Japan who can supply me some very hard-to-get fibreglass and carbon parts for Zs and other Datsuns. I can also get a big variety of parts for KPGC10 Skyline GT-Rs. If anyone is interested PM me. The list below is the price excluding freight. Please PM me for freight estimates. 240Z (S30) Carbon bonnet (carbon skin over fibreglass frame) $1250 260Z fibreglass bonnet with vents $650 Full Carbon bonnet $1750 Fibreglass bumpers (front or rear same price) $325 Carbon bumpers (front or rear same price) $535 Fibreglass cowl panel (under wipers) $355 Carbon cowl panel (under wipers) $535 Fibreglass front guards $1200 pair Carbon front guards (carbon outer skin, fibreglass frame) $2150 pair Fibreglass flares (240ZG style) $260 IN STOCK Carbon flares (240ZG style) $570 Carbon front spoiler with brake ducts $680 Fibreglass front spoiler with brake ducts $415 IN STOCK Fibreglass headlight cowlings (pair) $580 Carbon rear spoiler $500 Carbon rear hatch (carbon skin over fibreglass frame) $1200 Full Carbon hatch $1750 Carbon tail light garnish $500 Fibreglass doors $2850 pair Carbon doors (carbon outer skin, fibreglass inner shell) $3750 pair Full carbon doors $4450 pair 280ZX (S130) Carbon bonnet (carbon skin over fibreglass frame) $1200 Fibreglass front guards (pair) $1200 Fibreglass front spoiler $415 1600 (510) Carbon bonnet (carbon skin over fibreglass frame) $1200 Fibreglass front guards (pair) $1200 Carbon bootlid (carbon skin over fibreglass frame) $890 Fibreglass cowl panel (under wipers) $355 Carbon cowl panel (under wipers) $535 1200 (GB122) Carbon bonnet (carbon skin over fibreglass frame) $1200 240K (GC110) Carbon bonnet (carbon skin over fibreglass frame) $1200 Fibreglass front guards (pair) $1200 Carbon bootlid (carbon skin over fibreglass frame) $890 "Racing Jacket" carbon headlight panel $390 IN STOCK Fibreglass front apron $270 Fibreglass rear apron $270 Fibreglass chin spoiler $250 Fibreglass rear wing for 2-door $250 Fibreglass GT-R style flares $330 Fibreglass GT-R style grille $580 Carbon GT-R style flares $660 Fibreglass bumpers (front or rear) $300 Carbon bumpers (front or rear) $500 Carbon trims (around grille and tail light panel) $715 Fibreglass doors (for 2-door) $2850 pair Carbon doors (carbon outer skin, fibreglass inner shell) $3750 pair Full carbon doors $4450 pair Parts for 4-door are available too, please PM me Skyline RS (DR30) Carbon bonnet (carbon skin over fibreglass frame) $1250 Carbon bootlid (carbon skin over fibreglass frame) $980 Fairlady (SR311) Carbon bonnet (carbon skin over fibreglass frame) $1200 Carbon bootlid (carbon skin over fibreglass frame) $890 Full fibreglass door shells (pair) $2500
