Before I go on with the painting prep of the car, I should talk about the engine.
As I wanted an angry L-series engine and I had some budget to play with, I entrusted the engine build to Stewart Wilkins of SWR. Starting with an F54 L28 block, we added an LD28 crank, L24 conrods and KA24 pistons for a capacity of just over 3.1 litres and compression of around 10.5:1. The head is a P90A (big ports, small chambers) which I sourced from Japan. The head had already been ported, but SWR ported it more and added new valves, Tomei springs and a 298-degree cam with 14mm lift (big). The sump is extended and the engine features an SWR balancer designed to control the harmonics of the long-stroke engine. Final balancing was done with the new OS Giken TS2BD twin-plate clutch already attached to the crank.
Having been frustrated by a triple-Weber set up in the past, I decided to go with an OER injection set-up. This uses a Weber-style manifold with six 45mm throttles. The manifold was match-ported to the head, along with the long-primary Trust exhaust manifold. I found all of these parts second-hand in Japan too.
